Aux Switch Question
MikeJLURubi
Chillicothe, Ohio
2018 Jeep Wrangler JLU Rubicon
Medicolegal Death Investigator
I installed a LED Light bar and I want to wire the switch that came with the light bar to one on my Aux switches. The led light switch has a plug with 3 wires. I haven't looked at the aux switch wire on my Jeep yet. Does it also have 3 wires? How do I connect the switch wire to the aux switch wire?
Thanks
will1111
Will
Los Angeles
2018 JLUS
I wouldn't use the rocker switch from the the lightbar....disconnect it, connect the red (?) Wire to the aux switch you'll use (3 depending on amps) and control it with the jeeps switches...black wire should be ground and the 3rd wire (white I assume) is only to light up the rocker switch. That's how most switches are configured but w.o pics we can't tell.
MikeJLURubi
MikeJLURubi
Chillicothe, Ohio
Ok, so the red (power) wire is the only wire I need to connect to the Jeep Aux switch wire?
will1111
Will
Los Angeles
2018 JLUS
Yes...once u press the button on the aux panel. It'll power it on...make sure the light bar is grounded thou
MikeJLURubi
MikeJLURubi
Chillicothe, Ohio
Gotcha. Thanks for your help
rnocon
Richard
Los Angeles
2018 Jeep JL Wrangler Rubicon
Let me know hot it goes OP...
MikeJLURubi
MikeJLURubi
Chillicothe, Ohio
Sorry, it worked perfectly. Thanks
Outlawjeep
Ray
Louisiana
2018 HOUR, 1997 2dr XJ
How did you run the wires through the firewall? I haven't checked for a hole yet but I'm sure there is one
Rumblefish
Martin
Colorado Springs, CO
2018 Granite JLUR; 2015 BMW R1200GS
If you have the AUX switches, there are wires for the switches in the cabin and inside the engine compartment. I had to loosen the battery hold down to retrieve my terminate wires under the hood.
MikeJLURubi
MikeJLURubi
Chillicothe, Ohio
I didn't. I connected to the aux wires that are bundled next to the battery.
I used one for my light bar and one for my A-PILLAR lights.
