jeepoch
- Jay
- Nov 13, 2019
- Longmont, CO
- 2019 JL Wrangler Sport S 3.6L Auto 2 door, 2.5" lift, 35s
All,
I have recently installed the Teraflex Quick Disconnects and have been able to do several runs with them on some pretty difficult trails. Quick summary, there's no going back. This disco kit rocks!
I did have a little trouble getting them installed, but that was because of me not the Teraflex kit. I just couldn't break the bolts free on the original stock sway bar links. FCA must have used loctite and I didn't own an impact driver. A local 4x4 shop helped me out and installed everything for $50.
Disconnecting the sway bars are very easy, I have it down to between three or four minutes. Putting them back on is a bit trickier. The secret is to do this on flat level ground. Unfortunately, I must have never yet found a patch of ground flat enough.
This first side is easy, I do the passenger side first. The driver's side requires a little assistance. That's where my pry bar comes in handy. Just a little nudge between the sway bar and frame then everything goes back into place no sweat. The driver's side has the best place to apply the pry bar. It certainly would be nice to just reconnect them without needing to crawl under the rig, but lugging the crow bar around when wheeling is peanuts.
Regardless, I'll never (ever) consider any off-road adventure without disconnecting them. The added articulation is magic. Unlike with the Rubicon's and other disco kits that only partially disconnect, (this allows them to fully reconnect), the Teraflex kit allows for complete 100% mechanical release. My suspension is then free to travel the entire range that my springs will allow.
What a difference! Keeping the front wheels squarely on the ground (especially on open diffs) is traction heaven. My Sport now goes places where no one believes it should. I get complemented often for getting past obstacles that some Rubi's require help over. Granted, the stuck Rubicon's are typically stock, or close to it but nonetheless, they still have lockers.
With the amazing articulation potential that's now achievable, I feel my Sport is about the most capable rig around with open-diffs. Regardless, and with some humility I know it's limits. I'll let the modified bad-ass Rubi's mangle their under armor and leave tread marks on the biggest boulders they care to climb.
I'm just interested in going out and having fun. I'm no longer worried about getting into real trouble. With my aired-down All Terrain 35" Duratracs and the disconnected sway bar, I'm very confident my Sport will now take me anywhere I'm willing to point it.
Highly recommend this Teraflex kit. That is if your willing to do a little bit of finagling in getting everything reconnected. After a little more experience, I'll likely find that perfectly flat ground isn't the answer. A little upward slant toward's the driver's side may be the secret sauce after all.
Jay
Jay
