Suspension help
Laz
Tom
New Hampshire
2018 JLUS
Might be worth checking that the rubber isolators are all in place. Very easy for an uppers to drop out whilst mauling with the springs.
Also if it’s a Rubicon put it in low 4, disconnect the sway bar via the normal switch, make sure it confirms on the display that it’s disconnected, then reconnect again on level ground.
Good luck!
Thanks I’ll check the isolators too. One thing I did notice is he installed the rear sway links upside down. Not sure if that’s why it means but certainly affects the way the rear end handles.
Laz
Tom
New Hampshire
2018 JLUS
Right you want to have everything installed loose, then have the vehicle sitting on its own weight before adjusting angles and tightening/torquing everything down to prevent the suspension from binding up. If you adjust angles and tighten everything up while the vehicle is lifted, you're gonna have a bad time!
By everything you mean the new lower control arms ( both ends ) and the track bars correct? Sway bar links should be tightened though? Thanks!
RAMSTEEL
Rick
Virginia
2023 392 XR
Army (Ret), Fed Guy
Did you figure out what was causing the issue?
