Suspension help
Laz
Tom
New Hampshire
2018 JLUS
I had a Teraflex ST2 ( 2.5" ) with falcon shocks installed yesterday. While driving I could feel the passenger side was lower than the driver side. Got home and measured top of the tire to bottom of fenders. The driver side rear was 1.5" higher than the left and the Freon was 1" higher. Just talked to the installer, he said the only thing it could be was if they are settling or one spring was weaker than the other.
Anyone have any advice?
Thanks
Roky
Roky
North Central Florida
Thanks
I think those teraflex rear springs are corner specific. Meaning the longer spring on rear is supposed to go on the passenger side to compensate for fuel tank weight. I’m not sure if the front passenger spring is longer or not.
Laz
Tom
New Hampshire
2018 JLUS
  • Thread starter
  • Thread Starter
  • #3
Yeah I just read that on the installation guide. the rear are different but not the fronts. I just checked and they are on the correct sides. This sucks lol.
Roky
Roky
If you’re determining that they are incorrect by reading part number I would still take them out and look at them, easy enough to stamp the wrong number on something. I don’t read part numbers on springs, or trust the tag if there is one, when installing lifts, always lay them down and see if one is longer.
Laz
Tom
New Hampshire
2018 JLUS
  • Thread starter
  • Thread Starter
  • #5
Thanks. Would there be a noticeable difference in length? Is there any way to measure without taking them off?
Roky
Roky
It’s usually a noticeable difference. I’m not sure how much of a difference teraflex does, but it’s probably at least a half inch maybe more. You can drop the rear axle enough so the spring is loose to make sure it’s not compressed and measure them that way, but safer to take them out and lay them side by side.
Laz
Tom
New Hampshire
2018 JLUS
  • Thread starter
  • Thread Starter
  • #7
Thanks man. Appreciate it.
Roky
Roky
Also check to make sure your sway bar links are the same length if they’re adjustable, another member had that happen and made his rig lean.
Laz
Tom
New Hampshire
2018 JLUS
  • Thread starter
  • Thread Starter
  • #9
I don't think they are adjustable but Ill take a look. Thanks.
Clayton Off Road
Summit Sponsor (Level 3)
East Haven, Ct
Couple of things you can try and take a look at. The first would be to make sure both the control arms and sway bar end links, basically anything that's adjustable and is part of a pair, are set to the same exact length. You want to make sure everything is as close to each other in measurment as possible so that nothing is causing your suspension to bind up or sit awkwardly.
The second thing you could check is to make sure you aren't having any issues with faulty shocks. Basically all you have to do is unbolt each shock, watch to see if they droop down gradually and smoothly which is what you want, or if they seem to be stopping and going and having a hard time drooping down on their own, which is not what you want. Then you can test the up-travel for the same exact issue by gently pushing the shock up and seeing how smoothly it slides back up.
Hopefully this helps and good luck!
Laz
Tom
New Hampshire
2018 JLUS
  • Thread starter
  • Thread Starter
  • #11
Thanks for the info!
Laz
Tom
New Hampshire
2018 JLUS
  • Thread starter
  • Thread Starter
  • #12
Also, I read that you need to torque many of the parts after it is on the ground. If they torqued while in the air, I assume that could affect things?
Clayton Off Road
East Haven, Ct
Right you want to have everything installed loose, then have the vehicle sitting on its own weight before adjusting angles and tightening/torquing everything down to prevent the suspension from binding up. If you adjust angles and tighten everything up while the vehicle is lifted, you're gonna have a bad time!
Laz
Tom
New Hampshire
2018 JLUS
  • Thread starter
  • Thread Starter
  • #14
I think I should probably try that first. Thanks
Nick p
Nick
Uk
Jeep Wrangler, Land Rover
Might be worth checking that the rubber isolators are all in place. Very easy for an uppers to drop out whilst mauling with the springs.
Also if it’s a Rubicon put it in low 4, disconnect the sway bar via the normal switch, make sure it confirms on the display that it’s disconnected, then reconnect again on level ground.
Good luck!
Jim Marsh Chrysler Jeep
