Surfing - what to do with key
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
Thanks, I think the Faraday bag will work, that way someone can't just walk up open the door and start it.
Now - I also have a whistling noise it seems from the driver's side mirror (took hard top panels off for a bit, still there) - I've read through a few threads but no fix. It looks like the mirror is maybe just off a a bit where the outside of it is snapped together. Any ideas?
I've got a ton of ideas. You could say I'm kind of an idea person. None of my ideas have anything to do with rearview mirrors though. Good luck.
SurfJeep
Huntington Beach, CA
2020 Jeep JLU Willys
Can’t you run proximity entry off in uconnect? I don’t have proximity on my Jeep but I do on an older mpar and was able to do so. Then I took the metal key out with me. I looked at a Jeep manual online and it looks like it can be turned off. Worth a try?
Of course you would have to take your metal key out of the fob if that worked.
Speed331
Sean
Las Vegas, NV
2008 Jetta, 2018 Discovery Sport, 2020 Wrangler Sport S (on order)
My board shorts usually have a little bungee loop in the back pocket. I've always had a small waterproof bag attached to it and tucked in my pocket. Haven't ever lost one...
Ormond Beach, Florida
Retired at 55 ..
@SurfJeep
As far as I know, with the JL/JT, no...... you cannot turn off proximity in UConnect.
ajkitebrder40
Adam
Charleston,SC
'21 JLUR, Hydro Blue
My board shorts usually have a little bungee loop in the back pocket. I've always had a small waterproof bag/wallet attached to it and tucked in my pocket. Haven't ever lost one...
Yeah, I've done that, but I'm always worried with it, same with a wetsuit. To be honest, I usually surf/kite right in front of my Jeep anyways, so it's not that big of a deal. Just wondering what people did.
Retired at 55 ..
I wasn’t sure, that’s why I looked at the manual. If what I’m reading is corrrect, it looks like it should be possible.
@SurfJeep
I'll check tomorrow... I know you can change setting so both driver's and passenger door unlock or just the driver's door..... but in the same UConnect settings I don't remember seeing the option to turn off Proximity.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
There’s a TSB on a foam piece that seals the windshield that can get a fold in it. Fix is to drop the windshield and straighten it out.
21 Willys
Shoals Junction, SC
2021 JL Willys Sarge Green
Get a faraday bag as others have suggested, then have a $3.00 key cut. Put the key fob in the faraday and hide it inside of your Jeep, then either take the $3.00 key with you or hide it on the outside of the Jeep. It will only unlock the door and not allow the Jeep to be cranked. By hiding the faraday bag inside, if someone does find the key that you hid outside, they still cannot start your Jeep.
Reinen
2021 Jeep Wrangler JL Rubicon
Adding to this perfect suggestion, it's a good idea to store your keys at home in a faraday bag/box as well. It's not all that difficult to create a long-range RFID amplifier relay.
A thief can use such a relay to signal the key fob in the house, relay it to the Jeep so it thinks the fob is present, unlock the door, start the Jeep and drive off.
Faraday bags and boxes aren't special. Anything that fully encapsulates the fob in metal (solid or fine mesh) will block signals to & from the fob.
jadewolf
2012 JK Sport (sold), 2021 JL Rubicon
