Surfing - what to do with key
Bullwinkle
Lyle
White city, Or.
2019 Wrangler Sport S
Ok, real easy solution to this.
Settings > Door and Lock > Passive Entry - set to disable. This requires you to hit unlock with the key fob to unlock the door. Park, hide key as normal, lock the doors. Problem solved.
Try the pencil bag, i did it for years when I rodeo'd, cheap and easy....a pencil bag, and a carabiner to attach, poof, out of sight and safe...
ajkitebrder40
Adam
Charleston,SC
'21 JLUR, Hydro Blue
Yeah, so I have a hide a key, a bag, all of that. It was more the fact that proximity unlock was on so someone could just walk up without the key, unlock the door, start the engine and drive off.
I'm going to fix it with two things, faraday box and disabling proximity. Truth is, I generally surf/kiteboard right in front of my Jeep so there's no issues. It's mainly when I'm travelling, etc.
Dadawada
Barrett
Raleigh, NC
2018 Rubicon Unlimited, 2020 Honda Goldwing Bagger
Network Technology Executive
Remove the battery and hide the key on the car. You can also make a copy of the physical key and after removing the battery lock the key in the glovebox and take the copy with you surfing safely secured.
SurfMacJpMtb
DFW TX
21 Jp JLU Rubi, 17 Jp GC WK2 Quadra-Drive II
Turn off "Passive Entry" on screen setup, buy an oversize lockbox. I use the "KeyGuard SL-501 Punch Button Large Capacity Key Storage Shackle Lock Box, Black Finish" that I found on Amazon.
Jay 13
Jay
Toronto
JLUR
You might be able to surf on the fob ?‍♂
C’mon, That’s just silly!
As a surfer……you know damn well the Jeep fob is way to BIG to be used as a surf board! ?
Dougehr2
Doug
Illinois
2008 jk 2021 jl 2 door rubicon
Mechanic
Need to talk to local surf board company and ask if they can install a compartment in your board , bet it could be done
cwoll1321
Houston, TX
2019 JLUR
Too many posts to read through so apologies if this has already been said. I hide mine in the front bumper. It is far enough away to not unlock the doors. Rear is obviously too close but front works. I’m afraid that gigantic hunk of propaganda will ding my board so I don’t take it out.
ajkitebrder40
Adam
Charleston,SC
Yeah, so this post got way out of hand on random posts, I was just curious since I didn't have a choice on not getting proximity with a Rubi. So 3 options:
1. Turn off passive entry, lock doors, hide key as usual.
2. Test the distance you can hide it, I'll try the front bumper the back wheel was too close. I'll try the inside of the front and rear bumper.
3. Buy a faraday box to block RF, hide it as usual.
roaniecowpony
Retired Engineer
Coldeskimo
Peter
Sydney
Wrangler Rubicon JLU
OK most surf shops should sell a lock box that you could attach to your hitch or other location around the car. To avoid the issue of keyless entry just wrap the key in aluminum foil. This stops the transmission allowing you to feel secure to leave the key near the car.
