Sunrider for JL
BillG
BillG
Middle Tennessee
2018 Sting Gray JLUR / 15 Harley Tri glide / 50 Dodge Rat pickup
A side benefit I’ve noticed, is the gutter waterfall seems to be less with the sunrider than with the freedom panels.
Sorbs
Brian & Sunny
Colorado Springs
21' Ram TRX, 20' Gladiator LE
Mine is louder than the freedom tops with sound deadened. But I didn’t think at higher speeds it was significantly worse, although with a head wind it was pretty loud before.
Me too, on windy days my passenger side Freedom panel seemed to be noisest at higher speeds. With the Sunrider installed, it's about the same. I attribute the noise to the vehicle being shaped like a brick and the right angle of the windshield meets to roof there's nowhere for the air to go but into the nooks and crannies.
Oh well, until warmer days when the top will be open, crank up the music a little louder.
Sorbs
Brian & Sunny
Colorado Springs
Well I installed one today. It’s raining, so far no leaks.:like:
I’m not a fan of the instructions concerning the ends of the cables. Figured it out, but it’s one of those things that if you did several a day you wouldn’t think twice about, but as instructions are written, good luck....To anyone considering it. Just take your time. Your Jeep tool kit has all the required tools, and it’s not worth paying anyone else to install it.
Agreed, the instructions should state that "needle nose pliers are a godsend" and needed when fishing for those cables.
am1978
MD
2018 JLU Sahara Bright White, 2018 JLU Sahara HellaYella
‘Merica
Anyone have any close up pics of the cable ends installed. I am assuming mine are correct based on the instruction images, but real life would be useful. Waiting for a decent day to install it—weather.
Sorbs
Brian & Sunny
Colorado Springs
I should've but when you're in the heat of..."no, no, this way" or "try it like this" or after staring at it for 5 minutes, questioning its simplicity, and still being confused. Fear not, it is truly a facepalm when it goes together.
am1978
MD
‘Merica
Have it all assembled, just have not installed it. Everyone keeps making a big deal out of the cables, but seemed easy enough when I did it—wondering if I’m wrong. I’ll snap a pic tonight.
Sorbs
Brian & Sunny
Colorado Springs
It is easy but can be confusing if you don’t have the left or right side figured out. Once the cable is in it’s no problem.
BillG
BillG
Middle Tennessee
It’s kinda hard to explain, which is probably why the instructions are confusing. I found it easiest to sort of assemble it backwards, then turn the side rails back into position before bolting them. That avoided some of the flexing the cable has to do to be inserted correctly.
WXman
Central Kentucky
I'll do that next week. We're supposed to get heavy rain again. Been a wet year around here.
I did run a pressure washer over it last night after a 4-wheeling trip. Had the wand about 10 inches above the top spraying it all down to clean the mud off. Didn't see any water inside the Jeep at all. I'll keep an eye on it.
Parked on a grade in the rain. No leaks.
This thing leaks air, but doesn't leak water. Go figure.
WXman
Central Kentucky
Check this out. Shows the issue with the cable ends in detail:
am1978
MD
‘Merica
That guys says everything is a PITA, even freedom panel storage in the bag. SMH. It can’t be that bad. I’ll probably install the Sunrider tomorrow on the wife’s JL since my JL runs the softtop in the warmer months.
I am assuming this is what the cable ends should look like pre-fit into the door rails.
Jeep Wrangler JL Sunrider for JL 94B01D3D-DD52-4C27-B61B-68E39182F41D
Jeep Wrangler JL Sunrider for JL 193E39A9-BCBF-440A-9F8F-AAF237841D63
Mantacon
Eric
2018 Sting Grey JLUR
UPDATE: Installed the foam tape pieces provided by @BestopTeam and ran the leak test again, so far so good. I'll keep an eye on it but I think the leak is gone. Here is the images of where the foam tape was added.
Jeep Wrangler JL Sunrider for JL IMG_20181230_152423
Jeep Wrangler JL Sunrider for JL IMG_20181230_152433
am1978
MD
‘Merica
Was it leaking from both sides of the top (driver and passenger)? They provided two strips which you applied to the canvas end? The other two strips on the side rails come on the Sunrider from the factory, right? Mine has the two on the side rails.
Mantacon
Eric
No, just leaking on the passenger side. However they gave me a piece for both sides so I added it. Its the area on the material and covering the cable hole.
Slowpoke
Columbus, Ohio
22 Mojave & 22 Sport
Yes
Free review, so take it for what it's worth. Just installed a new SR today. Piece of cake. It's 57° a cloudy so I did a test drive windows up, top closed 70mph. Normal wind noise for a convertible, not bad at all. Had one on a JK so was not surprised. Then I opened it up, 70mph, of course it's windy. I found no need for the velcro tie downs, not rattles, bouncing or flapping. Then I did the garden hose leak test in the driveway. All good. Hope it stays this way. I feel much better now the I can have the roof open. Now if it would just warm up.
