jeeper4life73
The video in this post is from a 2019 JLU MOAB. It's lifted, 3.5in, running 37s. The dealership can't figure it out. I've checked everything i know to check. The knocking sound is present when you are between 8 to 21 mph and only when you let of the gas, slowing down. As soon as you accelerate, even the slightest bit, it stops, but if you let of the gas it immediately starts back up. It is not present in either case, if raised off the ground. The weight of the Jeep must be on the ground to produce the sound. I can feel the knocking ever so slightly in both the steering wheel and the brake pedal. I already removed the front drive shaft and the knock was still there.
If anyone has any recommendations or questions let me know.
