Stock track bar
Hasan mahajna
Hasan
Israel
Wrangler unlimited rubicon 4D 2020 2L turbo
Hello ,
I have a lifted 2inch jeep , a year after i lifted it , the track bar started to look like have issue with the bushing on the axle side ( it has a movement ) , i have the stock one , can i replace the bushing ? I know that the adjustable is better for me but its not an option cuz it cost a 1k$ here , or i can buy an aftermarket ( okman ) made in china ,, what do you suggest guys ?
Thanks alot
Wabujitsu
Sarasota, FL
2021 JLUR, 2020 JLU Sahara
Retired US Army
Hello ,
Thanks alot
Hasan, how much movement? Can you post a video? Do you have a shimmy or death wobble when driving it?
Hasan mahajna
Hasan mahajna
Hasan
Israel
Hi , it moves 1.5 cm ,, i dont have a DW but i hear clicking noise on bumps , all of the front end susp. parts is new , just the gear box and the track bar still the old and i intended to change them soon ,( steering issue and loose steering )
Wabujitsu
Sarasota, FL
Retired US Army
I’m sorry to hear that. I don’t believe the stock tie rod bushings can be replaced. Per the advice of my mechanic, who I trust, I recently replaced my stock tie rod and drag link, because of movement and clicking too.
Pape
Quebec
JLU Sahara
Trackbar should not tick unless it is loose.
You can replace the bushing if you wish but from experience the mount usually oval out
Wabujitsu
Sarasota, FL
Retired US Army
I just realized I posted about the tie rod and drag link, whereas your question is about the track bar. My apologies!
chulyn1
chuck
Alabama
2024 Jeep JL 2 door soft top Sport
I recently had my son replace the front trac bar bracket, tie rod and drag link with Synergy heavy duty parts. I also had Jeep replace the steering gear under warranty on my 24 JL. This took care of the steering issues I was having as well as beefing up the front end and steering for off road fun. The trac bar bracket has a replaceable bearing. You are talking about the axle side of the trac bar but could your problem be from the gearbox side instead where the bracket hole gets wallowed out pretty easily with a lift kit??
