hoag4147
- Rick
- Dec 13, 2019
- Colleyville, TX
- 2022 JLUR XR
- Vehicle Showcase
- 2
Is your jeep truly pulling to the right or does it go right when wheel is centered? If it is driving straight and the steering wheel is just off center then you need to adjust drag link to align/center the steering wheel as mentioned above and in the video. If it is truly pulling to the right as you drive it could be many factors. In this case, get the TSB completed, check tire pressure and have them check alignment after TSB completed.How does this affect the steering wheel when driving? Does it return to the position it was set at after playing with the drag link?
What are some suggestions for fixes for pulling to the right when steering wheel is dead center ? I am on order for the new steering gear from the TSB fix.
