Steering wheel no longer centered
StaindReality
Kansasncity
Ram 1500 crew cab black out
Why would my steering wheel now be slightly to the right to go straight. It’s not centered now or it pulls slightly to left if I try to center it. It drives straight if take hands off. Not alignment.
Will_Jeep
Will
Atlanta
Black 2108 JKU Sahara, Black 2016 Mercedes CLS400
Rubi-Zero
Nashville, TN
JL Rubicon , Audi S5
As will_jeep posted, that is correct as long as you have the stock drag link. Also if you are making the adjustment on your own, place a piece of painters tape around the center point of your steering wheel and then you can make your adjustments and see from the front of your Jeep if the wheel is centered. This may take a couple test drives and adjustments to get it perfectly centered.
StaindReality
Kansasncity
Thank you. I’ll see about trying to fix this weekend. It happened some time in last few weeks out of nowhere.
StaindReality
Kansasncity
I haven’t done anything to it to cause this change.
possible hit pot hole maybe? Idk.
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
Rubi-Zero
Nashville, TN
How can the steering wheel be centered?
So if your wheel is off center, pull the Jeep straight into your work area so the tires are straight. Mark the center of your steering wheel by wrapping a piece of painters tape around the center of the wheel. you will then loosen the drag link adjustment collar/sleeve. Once the bolt is loose, you will turn the collar/sleeve and you will see the steering wheel move with each movement of the collar. once it’s centered, tighten the bolt back up and test drive to make sure it’s centered. It may take a few tries to get perfect.
Deepc408
Deep
South Bay Area, California
Jeep Wrangler North Edition
Eng.
So my jeep wanders to the right as I drive with the steering wheel dead center. I got alignment done last week. The jeep still wanders to the right. and thus have to adjust the steering wheel to be slightly to the left while driving so I can go straight. Would fixing the draglink help my wandering issue?
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
No sorry. That would not fix pulling to the right.
Deepc408
Deep
Eng.
How does this affect the steering wheel when driving? Does it return to the position it was set at after playing with the drag link?
What are some suggestions for fixes for pulling to the right when steering wheel is dead center ? I am on order for the new steering gear from the TSB fix.
