gato
- Apr 4, 2021
- New England
- 2021 JLUR
So I wouldn't bother with replacing trackbar, tierod and stuff. Just get the iron steering box and make sure all steering/suspension components are tight and not bent and your steering is centered. Then put in a thru-shaft steering stabilizer. The Fox TS is the best bang for the buck and will suit you just fine.I’m not trying to lie I’m a pavement princess haha. I just off-road from time to time. But it’s my daily.
it wonders to the right. I’ve had the front end checked and tires balanced. Pitman arm was crap so that got replaced but it’s consistently got play in the wheel from 12oclock to 1oclock. Then pulls right just a hair. 55mph+ is where the most happens. Under that it’s just play in wheel. Then if I hit a large bump I get shaking that I can drive out of but the rarely happens since I bought the new set of wheels and tires.
If you don't change that steering box, you will still have excessive play.
Good luck.
