Steering Play Numbers
Bayrat
DA
NY and Fl
2023 Rubicon 392 - 2024 Gladiator Sport BAREBONES
I hope they come out with a fix because no matter how you look at this, it is wrong and could be dangerous. The attitude towards this steering issue seems to be, it’s a Jeep, deal with it. That’s fair to say on ride quality compared to other vehicles, but loose steering is not a quality of the wrangler. Maybe after umpteen miles playing with it.
So for now, I’m okay with it but can’t help notice that bit of a dead spot every time I drive. I’m going to give it time and go to another dealer to see what they have to say. However, I am sure they are all aware of it and have canned answers ready.
I am going to keep looking for the play in the steering input shaft, etc but I’m pretty sure the problem is in the black box.
I would love to hear from members that have, or have accomplished 100%.
This appears to have begun after the JK type of steering was deemed no longer sufficient, that is, sufficient enough to reduce JL production costs. That thinking shows in other components and processes as well ie the mixed metals and bare metal under handles and hinges.
m3reno
Sal
caldwell
2022 Jeep Wrangler JLU
I didn't want to tighten the screw any further as I don't know how it will react in cold weather. My previous Wrangler 2018 JL had an issue with the steering locking up when it hit under 40 degrees.
alparmer
alparmer
Al
Howie in the Hills, Florida
2022 JL Willys 2-Door
I had a 2014 JKUR that drove like a car. That’s why I didn’t hesitate buying another 9 years later.
Carolina Jeeper
Rollie
North Carolina
Verifying the input shaft coupling is tight first will keep you from wasting time searching for play in the steering box. I found the input shaft coupling loose and the pitman arm nut loose on mine. Both problems left by a dealership for me to find. They didn't get a second chance to touch my Jeep.
I think you'll be surprised at how much better a simple steering box adjustment will make it. Not sure you can achieve the 100% but certainly much better.
alparmer
alparmer
Al
It's all tight. The dead spot I have has to come from the steering box. It's minimal, but it's there. I just can't tighten the steering box screw anymore. While adjusting it, you get to a point that turning the screw no longer helps. That is the limit of that adjustment. I back it off a bit while maintaining the best dead spot. It's now drivable, but knowing it's not perfect really sucks especially on a new car. Dealer says it's normal. They showed me the twin of my jeep and it was like mine before the adjustment.
I just don't know if there is a jl out there without a dead spot. Even if it's a quarter or half inch it is still a dead spot.
Bayrat
DA
NY and Fl
This really is another failure of the JK to JL design transition from German to Italian ownership. After owning 4 JKs, the only two issues I had was water leaks from the hardtop and one broken oil filter can which was a common problem when they transitioned from the minivan V6 to the Pentastar.
alparmer
alparmer
Al
Didn’t know they went from German to Italian. Now everything makes sense.
Bayrat
DA
NY and Fl
Yes the Germans bailed ie Mercedes, purchased by temporary ownership of corporate bean counters but they didn't count well. So bankruptcy, then the current owner purchased the brand for peanuts.
alparmer
alparmer
Al
Wow. Let’s hope they get it together on this steering issue. There is nothing else like a wrangler. Italian brands tend to be focus on aesthetics. I do like the side faux vent and the dash is nicer. However, if trade it all for the steering to be how it’s supposed to be. Like I said before, I am at 98%, but should be a hundred. And why in the world would anyone need to do steering box adjustments right off the lot. Something got lost in the translation.
Bayrat
DA
NY and Fl
German vehicles are known for great road manners and they designed the JK. As I mentioned perviously, my 2 door JK with stick shift and oversized tires handled better by far than my JL, even with the new steering box. It's much better now, but still not what the old JKs are.
