Steering Damper
TCourtney
Terri
Dallas
2018 Wrangler unlimited JL, 2015 wrangler sport
I took my 2018 JL in for an oil change and tire rotation. After being on the highway, going about 70mph, the steering wheel began to shake pretty violently. Had to pull over (onto a bridge) thinking they must not have tightened the lug nuts or something like that. Called the dealership to come check it out and everything was tight. They said it might be because I needed new tires (i really did) and that maybe changing one of the more worn tires to the front caused a problem. After spending the money on new tires, same thing happened. Now they are telling me it the damper. I looked online, and found where there were problems with 2018-2019 dampers and they were replaced, however, when I put in my VIN, it says I have no recalls. Any suggestions on how to get this covered. I'm looking at another big chunk of money to have that done. Thanks!
1Evil55
here
2018 Sport
Get away from an OEM piece and buy a Fox or similar. Easy to install yourself and only takes minutes.
Badweissenbier
Bad
WV
2018 Billet JLUR
Just replaced my dampener. 46$ from a Jeep dealer.
It took me 10 minutes to purge it and put it on.
2018JLUR. Same symptoms as you. My tires were bad and I knew it. The dampener fixed the issue.
I have since gotten new tires as the old one’s probably took out the original dampener.
Mine was obviously bad as it was wet from leaking.
KevinC11
Kevin
Central Florida
2022 JLU Willys, 2023 JT Mojave
Gunsmith/EMT
All current model Jeeps should track straight and ride smooth with NO steering stabilizer installed. The stabilizer/damper does just that, dampens any small vibration or side/side thrust. A steering stabilizer will only mask the actual problem.
I would check wheel balance first.
I would re-torque every front end bolt with the Jeep on the ground.
KevinC
TCourtney
Terri
Dallas
My real question was, if there was a recall previously on the same make and model, shouldn't I be able to argue that it should be replaced for free?
Maverick909
I.E.
www.instagram.com
yes there is a recall tsb that called for a replacement but the replacement is trash. how many miles on the jeep? what size tires are you running? this can be a load of things. from loose/bad ball joints to under torqued drag link and tie-rod joints or bad alignment. welcome to the world of death wobble.
1Evil55
here
2018 Sport
Problem is that you'll be back with the same issue sooner than later.
