martoaj
This is what happened with mine ('22 Sahara 4xe) and I saw the same echoed by others on this forum. Without being prompted, my service adviser said the same; the steering stabilizer seems fine, but when the temps get low it reveals bad stabilizers that aren't actually doing their jobs -- presumably something in the valving, fluid, or tolerances of the stabilizer when affected by the cold.My 8 month old '22 has 21K and it started doing it when the temp drops below freezing. There is no way any parts can be worn out. It's a brand new vehicle with only highway driving.
As others have said here, if you have a relatively new truck and it's under warranty, you kinda have to follow what the dealership says. If they're only willing to replace the stabilizer at first, you have to let them make that mistake (if you believe it's a mistake) in order to move on to other components.
I don't know why the advice of "go on a wild goose chase at another shop 100% out of pocket" makes any sense on a new in-warranty truck. I often love the wisdom of these forums, but I also have to give at least some weight to a Jeep tech that's seen hundreds or thousands of Wranglers in their career.
I also don't really care if replacing it is a "band-aid" fix; I just want it to be fixed. Truck drove perfectly until we hit below-freezing temps, I find it hard to believe one of my ball joints or trackbar just magically got worn out overnight. It's clear there are a good 5-10 components that all have to be working properly in order to prevent DW; I don't see why folks here can be so positively negative (ha!) about one not making a difference.
