Steel steering gear
FireAnt21
Tony
Wisconsin
2020 Sahara Unlimited North Edition
Lineman
I have the aluminum gear and I’m thinking about going steel. I have a 20 JLU 2.0 etorque. I’m finding several part numbers (68551684AE) and also I’m curious if I need the software upgrade. I’m out of warranty so I can do it myself.
what’s the correct part number and will installing without updating cause any issues?
Philly_
Dallas / Detroit / NYC
2022 JL Rubicon
Not sure on the part number, but I believe a reflash to the Jeep’s computer is required after you swap the part.
I’ve seen a couple posts on it floating around over the years.
melendez69
Marc
Waxhaw NC
2018 3.6 JLR / 2013 991 911 / 2013 E92 M3
...huh?
They may have to flash.
Have you gone through the TSB thread ? It's massive, but there are different experiences amongst those who've had it done.
Carolina Jeeper
Rollie
North Carolina
There's a chance, that they may perform the steering box TSB even outside of warranty coverage. Did you already check and they turned you down?
Had mine done under warranty, but they didn't check their work. Steering shaft coupling was not tightened completely, causing play, and the large pitman arm nut was so loose that I could turn it by hand. So, check behind them if they do it.
garyji
Gary
Western NC
2017 JK Sahara, 2021 JLU Willys
Rollie, you need to name them. Stuff like this is total BS!!
G.
avidangler
Nick
2018 JLU Sport 2.0t
You could try reaching out to jeepcares. I was told there is a grace period (if you're out of warranty). I think the grace period was 24,000 miles beyond the powertrain warranty (I was past that unfortunately, lol).
dsgrey
Kevin
2019 JLU
I had the TSB done just before my basic warranty went out on my 2019. They had to flash.
JeepinPete
Pete
PA
'19 Mojito JLUR
Mechanical Engineer
You can replace the box without flashing anything. It does help. Did it on my '19. Plan to have the flash applied when I get the corrosion repair taken care of.
Pete
Dave928
Washington
2020 JLU Rubicon, 03 Silverado, 88 Porsche 928 S4
Aircraft Tech
had mine replaced under extended warranty. i think it got worse.
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
People have replaced them without doing any software. Let me know if you want a steel box for the 2 door.
https://www.jlwranglerforums.com/fo...ory-aluminum-steering-box.128010/post-2693970
