Steel bumper install question
gek
Code Monkey
  • Like
Reactions: Gio
10mmauto
10mmauto
Western NY
2024 Jeep Wrangler Willys, 2008 Mustang Bullitt
Retired LEO
jadmt
jeff
montana
Is this one the same for plastic and steel bumper? Do you also have closeout panel?
no they are two different pieces for the plastic and the steel bumper.
Gio
Gio
MN
24 Willys XR 2.0,
I ordered this to replace mine. Fits as I would expect a stock one to, and it cost much less than the factory replacement from Mopar.
https://www.amazon.com/dp/B09YNLMT1B?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1
Thank you.
I'm going to look into that as I don't think I have anything there other than what you see in the photo when you zoom in.
Jeep Wrangler JL Steel bumper install question 7lwRoai
I'm likely adding a BadLand winch in the semi near future.
OP,
What does your bumper look like underneath from the front?
And one more question:
Did you order you bumper with the winch guard cross bar or was that a separate order?
It looks exceptional.
Hello. I just replaced my OEM bumper with a MOPAR steel bumper. In doing so, you remove the plastic molding piece that goes between the back of the OEM bumper and the grill. Now the space is just empty. Does anyone make a piece to replace that plastic molding? The original cannot be reused, because it cannot be reattached along the back of the top of the steel bumper.
  • Like
Reactions: gek
greige
Robert
2023 farout
If you are getting a winch use the items below, the other two posts are wrong.
Kit contains:
Item # 7FX60RXFAA - Passenger's side Closeout Panel
Item # 7FX61RXFAA - Driver's side Closeout Panel
Second on this. The closeout panel does not work with the winch.
doc_riverz
dave
Austin, Tejas
’24 JL 2-door
Porsche tech, paramedic, fire engineer, retired.
That is where the winch goes.
10mmauto
10mmauto
Western NY
Retired LEO
Thank you.
OP,
The cross guard is separate. I got it from Quadratec:
https://www.quadratec.com/p/mopar/82215351-grille-winch-guard-jt-jl
and here is a pic underneath from the front:
That stamped part comes off when you add the skid plate.
  • Like
Reactions: Gio
Gio
Gio
MN
24 Willys XR 2.0,
Thanks for the info.
