Star Connector instructions?
Driggs
New England
Many
Anyone know of a video or instructions on how to remove and replace the green star connector behind the glove box? Also seeing one replacement part only has one row of connectors while mine has two rows.
sandy.h
Sandy
Oahu
2018 Jeep JL
Did you ever figure this out? Im having the same issue
Bob Burd
Bob
San Jose, CA
www.snwburd.com
You have both a one row box and a two row box. There's a problem in the dealer parts search that only brings up the one row version. Others discovered the two row part # and have posted it multiple places.
Swapping them out is not difficult. Read one of several threads here explaining it.
Driggs
Driggs
New England
Many
You can order one from this seller. It’s like $50 cheaper than the dealer. It’s connected with just one bolt and then slides off pushing towards the driver side. I then just removed one cable at a time and put them in the same spot on the new one. Solved my problem. https://www.ebay.com/itm/185633812123
Walk2019JL
Buffalo NY
2019 Wrangler Unlimited Sport
Does anyone know if the RF receiver associated with the TPS sensors transmit individually into the can bus through the plug connector located in the rear passenger wheel well.
Bob Burd
Bob
San Jose, CA
www.snwburd.com
The sensors transmit to the TPMS module, which then has a single CAN+/- wire pair to the plug connector in passenger back side.
