AFD
- Oct 13, 2021
- Northeastern US
- 2023 JL Rubicon (2DR/V6)
That's a good idea too, especially if you plan on road testing them and then making further adjustments.Bingo!
I made sure to leave my Jeep in the same spot so assuming its in the same spot then the blue tape sounds like a great idea! If you are not keeping it in the same spot then adding blue painters tape on the tires as well so you know where to 'chalk' the tires, will be required ?
I'm mostly just remembering back to the last headlights I adjusted. The upper cutoff was more of a slight upward curve for each lamp and after tweaking one and then trying to get the other to match up, I eventually lost track of exactly how far I adjusted them both from where they were in the first place. A bit of tape makes for a cheap reference of your changes if nothing else.
I fixed the issue though..
