3TV
- Jan 7, 2018
- Southwest USA
- 2022 JLUR 392, 2025 JLR
My '22 JLUR 392 XR is pretty weighed down with aftermarket steel skid plates, rock sliders, bumpers, and a winch. But a good part of the weight is also recovery gear, tools, and survival gear. I'm a bit of a survivalist, and my Jeep stays equipped with a lot of gear.
I have a Metalcloak 2.5" Gamechanger lift that gave my loaded down 392 XR 1" of lift. I would like another 1.5" to 2" of lift to help prevent constantly dragging the skid plates.
I weighed my Jeep on a local Loves truck stop CAT scale.
Gross Weight: 6510 lbs
Steering Axle: 3300 lbs
Drive Axle: 3210 lbs
This was with a full tank of gas, the usual daily supplies that are always in the Jeep, and two peoples on board. Weight of both said peoples estimated to be <350 lbs (she won't tell me how much she weighs).
With that in mind, what do people think regarding appropriate spring rates? Do I need to change to a higher spring rate, such as the Teraflex Outback springs, or just change from my Metalcloak 2.5" springs to 3.5" springs. I have Accutuned Fox 2.5 DSC shocks that I have dialed in fairly well. I am running the stock XR bumpstop length with no tire rub with 37" tires. I am not having a problem with the suspension bottoming out too much. The shock settings really take the bigger hits nicely.
