spring pads?
MyDaughters20JL
WA
20 JL Sport S
picking up a suspension setup off a diesel rubicon for my daughter's sport s: no spring pads are included, but will I just be able to use the current pads?
bow correction thingys?
any other issues I need to consider?
Fouts
Marc
Eastern Washington
2023 Rubicon Unlimited
Don't know from experience but pretty sure you should be able to use the current pads. I don't think I would bother with the correction pads at this point. Should be the same length spring just a bit stiffer.
Roky
Roky
If your daughters rig is a gasser then will have side specific springs, for fuel tank weight compensation. The diesel springs are not side specific so if you see a lean to passenger then you can get some rear correction pads and a 1/2” spacer for the front……
MyDaughters20JL
MyDaughters20JL
WA
20 JL Sport S
thanks: I"m assuming that I'll want to invest in some of the longer "lift-supplied LCA's" to compensate for the stiffer springs (even though it came with a steel box, she's still experiencing a "bit" of wander, but because it's NOTHING like her 2000 cherokee's "5" of play", it doesn't bother her)
you don't have the part numbers or a link to the correctin pads & such if I should need them, do you?
Roky
Roky
Sure…..teraflex for the front and Rock Krawler for the rear……..
https://www.northridge4x4.com/part/...jTCbgqwaTolqB9w7r9IGh9Xi2XwhVSRQaAsXZEALw_wcB
https://www.northridge4x4.com/part/...tuOB5qmWwix7DLQ7hCreHspn7RKRl2NwA95hbVFtLUm0M
