Asylum
Stock Alpine amplified?Kicker came with manta connectors. Dodge speakers were plug and play. Receiver got super hot too.(side note)
Your gain is set too high. I had the same problem. Turn that down and it’s greatAnyone have any idea why when I have the volume at zero there is white noise / fuzz coming thru the speakers?
I have the PSS-23WRA.
Check the ground with a multi-meter, make sure its a good ground. Other than that, I would turn down the gain on the amplifier.
I played with the gain today and got it to a point where the fuzz is minimal and the sound is good. Thanks!Your gain is set too high. I had the same problem. Turn that down and it’s great
You have an 8.4" U connect without premium? Try ohm-ing out the replacement speakers you have and see if they match the OEM ones. If they match then the only thing it could be would be the wiring.Regular non alpine. Non amplified
That’s what happened to me. Sound was way less and distorted/crackingSo I ordered a couple of pairs of the 77KICK25AB speakers everyone has been using to replace the stock speakers. The ones I put in the soundbar sound great. The two I put in the dash were crackling badly. I looked at the box they came in, and it looked like parts of a previous return label was on the box. I assumed they were both blown and returned previously, and the seller just never checked them.
Anyone else have this issue with the fronts crackling? I'd like to know before I order another pair.
But just the fronts?That’s what happened to me. Sound was way less and distorted/cracking
Fronts were definitely more noticeable.But just the fronts?
Ok. I've got no issues with the ones I put in the sound bar. That's why I figured the other pair were blown.Fronts were definitely more noticeable.
Something to keep in mind is that the 3.5 size is incredibly tiny. I would always recommend wiring on bass blockers on the 3.5in speakers at like 300hz. I would not be surprised if you were buying 3.5 speakers online that someone blew and returned.Ok. I've got no issues with the ones I put in the sound bar. That's why I figured the other pair were blown.
I am happy to report that the speakers are working wonderfully I did not do anything but start the car after a few hours of being parked in front of my office. This past weekend I added a sub-woofer under the rear, driver side seat to be able to use the firewall hole next to the brake pedal (I drilled a hole in the plastic cover just big enough to run the 8Ga wire to the battery and not have to seal), run the power cable along the bottom door frame trim on the driver side as well as the sub controller cable. Used "T" connectors and tapped into the speaker wires from the passenger side door column (where the seat belt is) and then run the wires inside the bottom passenger side door frame trim back and under the carpet under the back seat across to the sub. Also there is a very convenient ground bolt at the back of the bottom door trim next to the driver side, rear seat which is probable a foot away from the sub connection, Now the sound is amazing!. I would definitely recommend the speakers I described in my original post, so clear once you take out the bass from them and transfer it to the sub. It was time consuming, it took me probably 4 hours and one hour to finally give up on using the passenger side firewall grommet behind the glove compartment which was a pain in the neck and use the driver side hole (soooo much easier) but I wanted a straight shot to the battery), also tag another hour to being a perfectionist (*nal about how I do things). But in the end it all worked the way is is supposed to (fingers crossed LOL).I am by no means a expert on this subject. But I have been reading up on the subject quite a bit recently, and I fear that @Asylum is correct. The lower resistance is very difficult for the stock amplifier in your radio. It may have been the longer run time allowed it to build up enough heat that it shut down. I hope that you can get it fixed, I have been looking at JBL GX speakers too, they have a nice sound.
