Look through the forum. There are plenty of topics on this.Anyone have recommendation for speaker upgrade of the roll bar speakers and top dash?
JL Audio C2-400x speakers. Replaced all speakers and tweeters, added a JL audio sub and a JL Audio amp...sounds amazing.Anyone have recommendation for speaker upgrade of the roll bar speakers and top dash?
Awesome thanks will check them out.
Crutchfield will always throw in wiring adapters when you order speakers from them, I won't order audio anywhere else unless they don't carry what I need.Interesting Crutchfield is throwing in the Metra wiring adapter for free with Infinity. 9.99 generally.
That is nice like to give the smaller companies business also, Crutchfield has been around since forever. Only problem is no Metra wiring adapters in stock.Crutchfield will always throw in wiring adapters when you order speakers from them, I won't order audio anywhere else unless they don't carry what I need.
Do these infiniti speakers really work plug-and-play with the alpine premium sound system? I am asking because I have heard on the forum that the premium sound system completely shuts off any speaker that doesn’t give the exact correct resistance, or something along those lines.Scott.B
I just put a pair of Infinity 3032 cfx in my dash at $67 for pair two days ago and now they are selling for $45 a pair...
https://www.crutchfield.com/p_108R3032CM/Infinity-Reference-REF-3032cfx.html
So I just ordered another pair for the sound bar. Note Crutchfield web page says does not fit but my speaker and battery coach did this upgrade and just had to make new screw holes. By far 3032 or others 3.5 are better than the OEM Alpine Premium system speakers are.
Ok after talking to a few folks and google search have found to add the bass capacitor in series on the positive side (white wire) which came in the box and found them at the bottom... They are a base protector and I did so which sounds better... Some people reported a "power on or off" pop as reported. I think I heard it once but not again. I will accept the pop for great sound.
I'm leaving the 4" speaker in sound bar alone as it is mid range and no one has come up with and better idea that does not mean cutting up all the plastic. As for the Knee Speaker in the lower dash, I think they need to be replaced but it is a bear to do so per other as you have to take the whole dash apart. So doing reacher as what to replace it with or not as I control the sound levels with the sound settings.
I should also add I used my 12 yo G daughter with small hands to do screw removal and she put in some poly fill in the voids on the dash and will do same for the sound bar. It mades a great difference.
Hope this helps you and others.
I'll be doing mine tomorrow, as well as the knee speakers. Can report back then, but from information I've gathered it works fine with no resistors.Do these infiniti speakers really work plug-and-play with the alpine premium sound system? I am asking because I have heard on the forum that the premium sound system completely shuts off any speaker that doesn’t give the exact correct resistance, or something along those lines.
