Spare Tire Relocation for 33" tires
Altitude2020
Canada
2020 Jeep Wrangler JLU Altitude
I believe I need a spare tire reloction bracket. I have upgraded my tires to 33's now my Park Sensor randomly turns off. I was thinking the Rough Country non park sence bracket since it will give roughly a 2" raise to the spare and its not a 35" tire. Has anyone raised the spare tire because of a Park Sensor issue with 33's?
2nd 392
Ca
No, but did raise for 35’s. I am responding to warn you the RC plate is ~13-15 lbs that your hinges don’t need, It was wasted money and in the garage. I used Teraflex featherweight aluminum relocation brackets that also come with a spare snubber spacer kit. ~$150, you get what you pay for.
Altitude2020
Altitude2020
Canada
Good point. The RC that raises the tire 2 inches may be less weight. However I will check Terraflex.
Altitude2020
Altitude2020
Canada
Is it this one?
Jeep Wrangler JL Spare Tire Relocation for 33" tires Screenshot_20231220_184646_Samsung Internet
2nd 392
Ca
Nope- 2” RC 13-15 lbs. Teraflex featherweight, easy install, I didn’t even unplug the wires per instructions. Just set the stock carrier on a trash can. Removed the ugly rear view blocking 3’rd brake light and used a PNP QT light ring…. The RC plate doesn’t include the snubber extension kit either.
Jeep Wrangler JL Spare Tire Relocation for 33" tires 39CFBEFB-8E38-4E80-83E6-2701697469C3
Altitude2020
Altitude2020
Canada
That is what I'm leaning towards. I like the weight and zero cutting of the vent. Since my tires are only 33's I think the third brake light can be raised. Thank you, great info.
2nd 392
Ca
You can move it up to the next screw hole and just use the one if even needed with 33’s, but you may have to separate it and move the wire per instructions.
Altitude2020
Altitude2020
Canada
I think the wire definitely needs to be be loosened like the instructions stated. It's a 2 inch lift I beleive I read so that will be more than enough. My tire currently clears the bumper cut out.
Altitude2020
Altitude2020
Canada
Ordered, get it after Christmas. The Canadian price $257.00. Crazy lol...
maxp0wers
Northern California
Rubicon 4XE
I'm thinking this is exactly what I need rather than the terraflex tire mount kit.
I'm on stock ko2 33s with 23lbs wheels. May go to 35s but that would be my limit.
My 17x8.5 wheels have a -1 offset so I'm just trying to get some adjustment for the offset since the spare is hanging off the back about an inch and a half farther out.
Can you get rid of the oem 3rd brake light with this kit? Need to relocate license plate to spare and was going to install ORO third brake light/license plate lite
Would make sense to have 4 rear lights.
2nd 392
Ca
If you are referring to the Teraflex bracket kit it will do the opposite of what you want. I am presently running it to lift my 35’s 2 in, the brackets also put the spare out 1.35 in. It works good with the stock 7.5”/44mm wheels, but if I go the 8.5”/1mm I’m considering the adjustable one will likely be needed to tuck the tire back to eliminate camera-sensor issues/false warnings per reports. The Teraflex adjustable comes with a center 3’rd brake light mount but not a license plate mount. With the brackets I use a QT PNP light ring.
