Spare tire carrier
fzaino1
New York
2018 Jeep Wrangler sahara jl
I have a 2018 Jeep Wrangler sahara jl. I just purchased fuel assault wheels 20x9 with fuel gripper AT 305x55 tires, I want to know if I can install the spare tire on the factory spare tire carrier. If not, which spare tire carrier should I purchase that is stable and recommended
CJ-ING-RJ
RJ
Iowa
18 JLUR, 73 CJ5, 07 Electra Glide
That's only a 1/2" taller and 3/4" wider than a stock Rubicon tire. Jeep claims the factory tire holder will fit 35's. I say grab your wrench extend the third brake light up and slap that tire on the back.
JIMBOX
JAMES
FERNLEY NV
RETIRED
YUP, the tire will fit easy, but
You don't mention what the Back Space is---so the stock BUMPSTOPS probably won't work--
You'll have to get EXTENDED bump stops, or add material for the WIN !
Good luck
JIMBO
wibornz
Ted
lansing, Mi.
JL Unlimited Rubicon
I have a 37 in tire on beadlock wheel mounted on the stock back tailgate. You may have to extend the tire isolators. This is easy to do. I used three hockey pucks, drilled holes through them. I pulled the stock isolators out of the tailgate, cut the rubber nub off. Then ran a 5 inch bolt through the isolator and through the hockey pucks Put a well nut on the bolt and then attached it to the tail gate. It is very solid and does not move around. You may not have to do any of this. I am just saying. It may not be necessary to buy all that other stuff. I will add a different bumper/tire carrier as soon as the one I want is released.
Jeep Wrangler JL Spare tire carrier 20190108_125732
Jeep Wrangler JL Spare tire carrier 20190108_130124
fzaino1
New York
Good luck
JIMBO
The back space is about zero,
Good luck
JIMBO
the offset is practically zero, I was thinking about the mopar tire carrier kit because the tire might be too heavy for the stock carrier
JIMBOX
JAMES
FERNLEY NV
RETIRED
NOPE that's not right--they don't MFG an auto wheel with "0" BS, only ATVs and lawnmowers--
If the offset is "0" then the wheel mounting surface is at the CTR of the wheel, which will give a BS of 4.5" on a NINE INCH WIDE WHEEL !
CHECKITOUT
JIMBO
anotheraznguy
Tracy California
Mojito JLUR
CHECKITOUT
JIMBO
Actually, that is incorrect. a 0 offset wheel on a 9 inch rim is actually a 5" backspace. when you measure wheel width, you are measuring inside the wheel where the tire sits. Backspacing accounts for the inner portion of the rim.
a Negative 12/13 would have a 4.5" Backspace
Here is a sample pic of offset vs backspacing.
Jeep Wrangler JL Spare tire carrier Backspace-Offset-Diagram-Header-840x
fzaino1
New York
So can my new wheel and tire combo (20x9 fuel assaults with 305x55 tire fuel gripper at) fit on the stock tire carrier with no issues? I was thinking about purchasing the mopar mounting bracket if needed.
JIMBOX
JAMES
FERNLEY NV
RETIRED
Thanx Mojito JLUR--crap I forgot about the mounting diff.--4.5 to 5" BS is probably OK for Fzaino1 wheel--
I told him to try the sp-atre anyway to MEASURE THE BUMPSTOP DIFF.-
Have a great day-
JIMBO
