Soft top guys
Steph1
Steph
Quebec, Canada
Jeep JLU , Audi Q5
Any manipulation of the soft windows when they are not perfectly clean, will scratch them.
rolling them up is not an option either, as the strap that keeps them in a roll will leave its imprint on the windows.
au176
WNY
2021 Islander, 2020 Newmar Ventana, 2014 HD Road King
Tired again
I use the Mopar bag if I take the windows with me.
If I leave them at home, I hang them vertically from this homemade rack on the garage man door. (Running out of wall space in the garage! :LOL:) Two top rails for the side windows, two bottom rails for the back window, and a back screen window. This is still a work in progress. I still have to cut the top and bottom frame pieces, and two more thinner vertical pieces to put behind the metal rails to help support the windows' "tabs". Eventually, the wood will be painted to match the door, and I'll do a Rustoleum hammered finish on the metal.
Right now, all the summer stuff is buried in the back of the garage, otherwise I'd post a pic of them hanging.
Jeep Wrangler JL Soft top guys IMG_5539 Larg
Erievon
Al
Cleveland, OH
23 JTR, 21 JLU (Low) Altitude
I’ve seen that spot on the 2 door. Haven’t tried to set it in there cause the retracted top sits there. Last week I was by myself and leaving an appointment when I decided to remove the tops and sides and put them between the front seats and rear seats and folded the rear seat up to make sure they stayed in place while driving home the 56 miles from the VA.
I don't have a 2 door so I don't know, but on the 4 door the top sits behind the wheel wells. This spot is in FRONT of the wheel wells.
beachbumm78
Kristy
Phoenix, AZ
2020 bikini blue Rubicon
Athletic trainer & Massage therapist
Ha, that Amazon one looks exactly like the one factory one that came with my 2024 Willys and cost me $75! The rear windows fit in this bag really well and with a little patience, the bag fits behind the rear seat of a 2 door. I even have room left over for a pair of Bestop fabric half doors. The bag also works well to hang/store the windows in my garage when I do not need to take them with me. As far as scratches go, there is a big difference between scratches from branches and the blurry haze you get from dirty windows rubbing together when stashed loose behind the rear seat. Whatever way you go, having the windows out and the top down on a nice day is the best.
It does look identical! I guess I should have done a bit more recent research than impulse buying 🤪. Last time I looked to get one they were quite a bit more than that. Glad to hear the bag works so well for you. I’ve usually just found a spot in my spare bedroom only them so looking forward to the bag
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
Where are you storing your windows when you don’t have them on? I have taken my top down a few times in the wild after some rain when the sun was shining and kept them in my rear seat and they got scratched up. If i take them off at home I just set them on the work bench cause I don’t have a storage for them yet so what are you guys using!? And how do you keep them if you sporadically take them off not at the house?
I put them on a blanket on a shelf in the garage. I place inside to inside for the side windows, then outside to outside for the rear window. Worked pretty good for me. I just recently screwed in a couple hooks to hang the rear window with the bar.
dsgrey
Kevin
2019 JLU
I just hang them on clothes hangers with plastic clamps in the garage. I've been doing this for 6 years and they are usually hanging most of the time from April until November. No issues.
Jeep Wrangler JL Soft top guys IMG_1523
