Soft Top 2-Part Question….
Mccorm67
Tim
New Haven CT
22 JLU Sahara
I was traveling for work and witnessed a colleague trying to fit a s-ton of luggage in their JLU wrangler and was struggling because the “glass” portion doesn’t lift up like the hard top does. They had to fit everything through the lower portion. Has anyone found this limitation to be a problem?
Second question: is there any significant difference between the premium twill soft tops from Bestop vs Mopar that might make someone choose one over the other?
Tx ✌?
JP29
Zach
Olathe
2020 JL Sport
Idk why he had that issue. All you need to do is unhook the window at the corners and sides and it and the bar it's attached to can flip up onto the top. And no difference between Mopar and Bestop - Bestop actually make the Mopar tops too.
KJKWillys
Kirk
CT
2021 JLU Granite Crystal Willys - 6 Speed Manual
For me, if we are loading groceries or a couple suitcases in the back it’s not really an issue but you may need to kinda duck under the bar to tuck things back. If you are putting something larger back there you can pop the lower support out and “untuck” the sides of the window to allow a larger opening. Then just tuck everything back in and drive. Not as easy as flipping up the hard top window by definitely easily managed once you get used to it.
Mccorm67
Mccorm67
Tim
New Haven CT
22 JLU Sahara
Huh interesting. She is a relatively new Jeep owner so may not have figured out how it works. Thanks!
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
As stated, you just undo the sides and flip it up over the top, open all the way. It takes longer to cough or fart than to fully open the soft top rear window.
Mccorm67
Mccorm67
Tim
New Haven CT
22 JLU Sahara
Bahahaha fair enough, now I’ll know this when I pick one up ?
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
What kind of tuberculosis cough and IBS farts do you do?
Like, I'm a new grandpa so I have some good 2 or 3 foot farts but I'm quite sure none are longer than getting out, walking to the rear and moving the window. ;)
Mccorm67
Mccorm67
Tim
New Haven CT
22 JLU Sahara
Regarding the Mopar top, it’s several hundred dollars less on Mopar website, when compared to same top sold by Quadratec. Why would one pay more to Quadratec for the same top?
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
I would guess it come down to shipping costs.
JPAloha
Saskatoon
2019 JL Rubicon 2 door, 2022 JL Rubicon 4xE, 2018 JL Rubicon 2 door
Accredited Financial Planner
As stated it’s very easy to flip the rear window up…..but…in defence of your friend…caution should be used if it is very cold as it could crack the plastic window.
Dyolfknip74
2021 JLU Rubicon
Can't say I have ever heard of a soft top window cracking from the cold. I ran my JK one through a few winters with multiple sub -30° C throughout.
I mean maybe if someone is dumb enough to hit it with something but I still haven't seen it.
Jeff4374
New Jersey
2021 Willys JLU
