Slight bounce when low speed. Thoughts?
roaniecowpony
Retired Engineer
While greatly possible, that would be some serious crappy compound tires. Only tires I ever recall having that specific issue were the first generation milestars. Heck even our lifted golf cart with Kenda tires don’t do that and it’ sits for weeks with no use with a ton of weight on them. But once again, I know it happens.
It's not the compound that causes it.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Something to consider is when it’s happening. On acceleration you get front to back weight transfer, making the front end lighter. Could be impacting why the rotation didn’t move it.
BGB9
BGB9
Brandon
Nolensville TN
2019 Jeep JLU, 2013 Jeep jku
A bounce would typically be due to something wheel and tire related. Alignments typically help with steering feel and even tire wear.
I'm a big fan of KMC's XD series wheels. I've had their XD138 Brutes for over 60k miles now. The one downside is that they are only lug centric and require hub centric rings. I don't know if they were supplied by KMC or the tire shop, but after several rotations, the nylon spacer rings were starting to loosen just enough to cause a similar feel on my front end. Only difference is that I was feeling it mostly in the 45-55mph range.
Research led me to finding out that nylon rings are great for extreme temperature environments, but they only hold dimension for so many rotations due to having a heavier and larger wheel and tire getting dragged on and off of them. I found a set of aluminum rings that are supposed to hold dimension longer.
They smoothed out my front end. I still haven't gotten around to swapping the rear rings, but will do that on my next rotation.
I had no idea that you needed rings for aftermarket wheels. I’m going to have to pull one off to check if I have them or not. This may be the issue. Is there a certain size I need?
BGB9
BGB9
Brandon
Nolensville TN
You are tightening in a star pattern then torqueing in a star pattern right? Not going to completely eliminate the potential for being off center but helps without rings.
Yes, I hand tighten in the air then let it down on the ground to tighten to torque specs in a star pattern.
GATORB8
CLT NC
You don’t have to, but it can help. It’s like an adapter. Jeep hub size to wheel hub size. It’ll be in mm. Around the 70s IIRC
Edit: these are mine, as @Headbarcode mentioned you may want metal.
StanceMagic Hubcentric Rings (Pack of 4) - 71.5mm ID to 78.1mm OD - Black Poly Carbon Plastic Hubrings - Compatible with Jeep Dodge Chrysler with 71.5mm Hubs and 78.1mm Bore Wheels https://a.co/d/0Nvau9u
BGB9
BGB9
Brandon
Nolensville TN
I just ordered a pair to see if it corrects the issue.
BGB9
BGB9
Brandon
Nolensville TN
These are Metric 121 E Loads, so they’re rated at 80 psi instead of the standard 65 you’ll see in say a 35x12.50. Normally means you’ll run a little higher.
Doesn’t hurt to drop to rule out pressure, hell go to 25 and see if that fixes it. Short term testing isn’t going to hurt anything.
No change from a spring and shock change really rules out suspension. Alignment would be toe, which wouldn’t change but that’s more steering feel.
I dropped the tire pressure down to 32 psi and seemed to quite it down but still wasn’t gone. I’ll see what it does after adding the rings. Thanks!
beaups
Sean
Ohio
2020 JL
You don’t. And if your wheels use push through center caps you can’t use a ring anyhow.
