Sky One Touch top leaking in hard rain
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Just searching a resolution. I just received my Wrangler Rubicon 392 a couple weeks ago. Yesterday we had high wind and heavy rains. I opened up the driver rear door to put something in and my leather seat was very wet, as well as carpeting surrounding. Anything in particular I can look for?
I would think that the most obvious thing to do would be to take it to a dealership.
Calli74
Tim
Massachusetts
(Ordered 2023 Rubicon 392), 2002 BMW E39 M5
Indeed it would. It would also be the most time consuming and inconvenient option. Hence asking the question here. Seeing if others had the same issue and realized (and could share) a quick DIY fix.
Ratbert
PNW
Software Engineer
If it's leaking it's defective. And yes, a quick DIY fix might make the leak go away for a while.
bterra
Canada
2023 Jeep Rubicon Xtreme Recon Edition
I got by Jeep back from the dealership 2 days ago & I washed it today with the water hose no hard pressure and it’s still leaking it’s going back to the dealership tomorrow
My 2023 JLR is leaking in the exact same spot. I'll have to take it in also. I wish someone had a resolution to this but im having a hard time finding one.
Jeep Wrangler JL Sky One Touch top leaking in hard rain IMG_6201
spdracer888
Usually NY; often elsewhere.
2024 Wrangler 4xe High Altitude
Has anyone found a solution? Here's mine ('24 High Altitude) same spot and after heavy rain:
*** Currently it's at the dealer, they found the leak, but doesn't have a solution yet. ***
spdracer888
Update: dealer found and fixed the leak. It was due to the side weather seal: 1) not seating properly and 2) wasn’t long enough to reach the back of the perpendicular seal.
BiggerinTX
Austin, Texas
2019 JLU Rubicon - Ocean Blue
Mine is leaking in the same spot, but took several years to start. Was it a quick fix, planning to take mine to the dealer and see what they say. If there is any more detail you have would be great so i can point them in the right direction.
R4NS0M
Natalie
Austin, Texas
youtube.com
2024 392FE, 2025 G580
Is yours leaking from the SOT top or from the side panel thing, or are you unsure where it’s coming from?
BiggerinTX
Austin, Texas
Appears to be at the very back of the cloth where it meets the back panel. I took the side panels off and cleaned the gaskets and water management channels to allow those to drain, but no luck so far.
BKLYNJeep23
Anthony
NYC
Waiting Patiently
What is the part number for the seal? And then the other question is what is the weatherstripping supposed to look like in the front cause I keep getting the leak over the driver side vanity mirror and it’s so annoying.
