Size up tires
Juice7598
Lake Ridge, VA
2022 Jeep Wrangler Unlimited Rubicon
There is my Jeep with the factory LT285/70R17 tires. I haven't done any off-roading yet but would like to experience some of the Jeep trails near me which are mostly rated easy. I would like to go a bit bigger and am looking for recommendations (tire, size, wheel size, lift kit, leveling kit, etc.) that won't cost too much $$$. Since I will not be doing a lot of off-roading, this would be mostly for how my Jeep looks, but would also have a functional purpose for some light off-road.
Jeep Wrangler JL Size up tires Jee
KrzybonesJLU
Vince
CA, Orange County
2019 JLU SPORT S, 2024 WILLY's
if you are going to say the words “not going to Cost too much” and no plans on doing any serious wheeling then just go up to 35’s and call it a day. Just my opinion though. I don’t do any serious wheeling mostly just trails and stock gets the job done in what I use the jeep for which is daily driving and camping.
But you do you make the jeep look how you want it.
yokramer
Snark Incarnate
You dont need larger tires you will waste your money.
That said just go to a 315/75 (35") and call it a day.
Juice7598
Lake Ridge, VA
Thank you
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
No lift, 305/70/17 which is a true 34.
yokramer
Snark Incarnate
yokramer
Snark Incarnate
But again @Juice7598 you will just be throwing money in the trash if you are replacing your tires if they dont need to be replaced. A stock Rubicon (even the long school bus 4 door) Will handle those easy rated trails. Go out and drive them first before you throw money at the Jeep that you dont need to.
Juice7598
Lake Ridge, VA
That makes sense, but I'm also considering bigger tires for aesthetics too, just something I'm considering. Thanks again
yokramer
Snark Incarnate
And thats a perfectly valid reason to replace them, and you can get some money back for your stock take off tires as well. I just hate seeing people throw good money after bad because they think they need 37s and 5" of lift to go do some off roading.
kah.mun.rah
Merenkahre Jr.
Duat
Would I need a leveling or lift kit?
No. 35s will rub the plastic in the rear fenders at full flex but is ok on a JLU Rubicon for moderate trails. The only thing you will need to do is adjust the brake light to be taller on your tire carrier to clear the 35" tire and get a programmer (Tazer JL mini) to program your Jeep to the new tire size.
Opus
Midwest US
www.jlwranglerforums.com
kah.mun.rah
Merenkahre Jr.
Duat
