Side Cameras
mciaio
Michael
Clinton, CT
2020 JLU Sahara
Hi, I'm wanting to add side cameras to my '20 with the 8.4 Uconnect. I drive with the doors off a lot in the summer and hate the add-on mirrors. How many aux video inputs does this radio have? My original plan is to get a 12 volt powered switcher and have it trigger off the turn signals or if the radio has 2 inputs just use them. I have the factory backup camera, but I am unsure if you can have the backup, cargo and front cam in stock configuration.
jludave
The Isle of Long
IT Manager
There are no standard aux video inputs on the 8.4" radio. The OEM cameras do not use standard connectors/inputs. The stock cameras are pinned to the large connector that connects to the back of the radio. You can add a front camera such as the one offered here.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
It's capable of at least one, hardwired, but at less resolution then OEM rear. Tazer can trigger turn signal cam, but I believe it can just do the OEM rear cam.
jludave
The Isle of Long
IT Manager
Correct. There is no way to add an additional high-definition cargo camera input to the JL radio.
Correct. It displays the rear camera when either turn signal is active.
dav7922
Corinth, MS
2021 Jeep Wrangler Unlimited Rubicon JLUR
I just used my Tazer on Saturday to turn on this turn signal cam feature. It is handy and helps with the blindspot view.
REGGAVEGGA
Reggie
Cincinnati , Ohio
2020 Jeep Wrangler JL
If you hate the mirrors sticking out. Some have put a small mirror on the flat surface of their outer air vents..
2019JLUS
19' Sport S
You will need an aftermarket headunit for this ability. My android headunit offers multiple video inputs for 360 view, but it's too daunting of a task for me.
