Shielded cable replacement - *Badlands Winch*
Terrymo
Terry
2023 JLURXR 3.6 ET
I'm also going to re-route the cables. Red arrow is where the wires go now. I was thinking either somehow under one of the yellow lines. I guess I'll see what I can do once I get into it.
If I’m not too late you can remove three bolts, lift up the air box and intake tube and prop it out of the way. I routed my cables through a couple of cable clamps attached to the front of the battery box.
Jeep Wrangler JL Shielded cable replacement - *Badlands Winch* IMG_0655
Jeep Wrangler JL Shielded cable replacement - *Badlands Winch* IMG_0654
Jeep Wrangler JL Shielded cable replacement - *Badlands Winch* IMG_0651
Jeep Wrangler JL Shielded cable replacement - *Badlands Winch* IMG_0652
Jeep Wrangler JL Shielded cable replacement - *Badlands Winch* IMG_0653
SadRobot
Los Angeles
2025 Prius LE
I ended up going up through the fender wells and between the air intake and the battery.
Jeep Wrangler JL Shielded cable replacement - *Badlands Winch* IMG_4825
Terrymo
Terry
2023 JLURXR 3.6 ET
Can you zoom out on a pic showing where those Torx bolts you circled are on the winch. I’m disoriented What model of winch is it?
SadRobot
Los Angeles
2025 Prius LE
It’s a Badlands Apex. I did end up getting them loose but snapped one in the process.
I’ll do a full write up with pics in about an hour. I’m now taking a well derserved lunch break to celebrate my mild success.
SadRobot
Los Angeles
2025 Prius LE
Well this is getting returned. It's supposed to be 2" wide. Is there something I'm not understanding here? I thought maybe then 2" was the shrink size but that can't be either at a 3:1 shrink ratio.
I don't understand what this could be used for as it could probably fit around my arm.
Jeep Wrangler JL Shielded cable replacement - *Badlands Winch* IMG_4831
azjl#3
North AZ
i still use your red route. But I do wrap the cables with that knitted poly material wrap. I could not get yellow route to work unless i took air box out, and I may have needed longer cables. I simply zip tied the double wrapped winch cables to various things going up next to rear of radiator. It has worked for 12 years.
azjl#3
North AZ
Well I hit a bit of an issue. I can't get into the top of the winch to bolt in a new positive cable.
It looks like these have to come out to get inside the box but they won't budge at all. Anyone have any ideas?
heat
SadRobot
Los Angeles
2025 Prius LE
I almost did the same route but didn't want what happened to happen again. It got shredded on some belt in the engine bay because I didn't know what I was doing.
Hopefully this lasts now the way I have it.
