Service Stop/Start System After Amplifier Install
zw470
McFly
PA
'21 JLR
Installed all new speakers and a 4 channel amp using the PAC AmpPro last week. This morning when I left for work the service stop/start warning came on. I didn't have time to dig out my scanner but I was able to confirm that the amp is turning off with the Jeep. Main battery was replaced in late 2023/early 2024 and the aux battery was replaced last March. Start/Stop itself has been disabled via Tazer since 2022.
Could something from the install be causing it? Just a coincidence?
wanderer
Ralph
Carlsbad CA
Engineering Geologist
I have a similar issue with a portable plug in refrigerator
Aonarch
Mike Hawk
North GA / MT
'25 JLUR '41, '24 F-150 V8 4x4, '22 Mach 1 6MT
Motorsports Engineer
Did you disconnect the battery and the aux battery when installing?
zw470
zw470
McFly
PA
'21 JLR
Got the scanner hooked up and got the P00FD "batt b state of charge performance" along with two seat sensor related codes and one code (B1BE7) it couldn't define. When I googled it a thread from here was one of the first results, and this was one of the replies.
Hi there, I had the same error U115F/B1BE7, together with the 'service stop/start' light and message.
Since I had just removed/ replaced the seats, I checked if the contacts were all securely fastened, and one of them was not. Once i plugged it back properly, the CELs and all messages disappeared.
Edit: this was on the driver side.
I had both seats out for the install, so I guess I need to go back and check all the connections again.
