PyrPatriot
Has anyone implemented the Select Speed Control to help going down hills covered in ice? I am seeing that having the wheels keep spinning a little when descending a hill, or even on a flat surface, that is a sheet of ice helps maintain control. Before I try this on my driveway and risk crashing into the neighbor's garage (driveway slopes down at about 10 degrees for about 2-JLU lengths, exits into an alley with neighbor's garage immediately across from driveway), I wanted to see what I should expect. Only time I ever tried this feature I ended up giving up because it sounded like gears grinding and to a newby Jeep owner on his first offroading trip I just used breaks. Sounded like gears grinding and all sorts of aweful so I decided to try later, well today might be "later"
