Security gateway module location 2021 Sahara 4xe
Dawnjoel4xe
Joel
Arizona
2021 4xe
Has anyone located the gateway module on a 2021 4xe Sahara. I looked and am unable to locate it. Looked directly above the OBII connector and it’s not there. Any help would be helpful!
speedymart
mephis
2021 jl
Good/bads news is by the time we get another wrangler generation they've started turning the SGW modules into not only a gateway module but theyve begun burring them deep in the dash. Won't start without it plugged in and takes a good amount of time to get to them.
C.Sco
2023 4xe Rubicon
The trick is to take a couple hot yoga classes at a local studio before you try to get to the SGW plugs. It can also be helpful if you've got previous experience escaping from Shawshank.
Jeep Wrangler JL Security gateway module location 2021 Sahara 4xe shawshank-crawlin
theblackshjeep
Los Angeles, CA
2023 Jeep Wrangler JLU Sahara 4xe
Assuming you will probably need to get to these more than once, get some SGW extension cables from ZAuto, save ya a lot of scraped fingers
Bisquit4407
Marion, Tx
2023 JLU Willys , 2021 GCL
Pinky promise you’re not trying to steal someone’s Jeep?
Where is this diagram from? Looks helpful for locating wiring and modules.
Bill_BCNtoNY
Bill
NY
Ocean Blue JLU Sahara 3.6
Advisor to Boutique Consulting Firms and Solo Practitioners
absolutely! Still remember all thecuts on my fingers, knuckles and wrists
Bisquit4407
Marion, Tx
Dang. I was hoping to get a location of the factory modules so I could start looking for some upgrades at the wrecking yards around here. Looking for the trailer, connected services and auxiliary switch modules and required stuff. Thanks for the info though.
oomikeyoo
Ontario, Canada
Toyota Highlander
anyone know how the obd looks in the engine compartment? was perplexed about what was going on with tazer mini and just found a nest in the engine. would like to know where i can check if wires to this have been chewed up. thanks in advance.
