Rugged Ridge Arcus Bumper Not Fitting
Mgriz
Georgia
2021 Jeep Wrangler Unlimited - Sahara
I am running into an issue when trying to install the Arcus bumper on my 2021 JLU Sahara. The winch plate does not fit between the frame horns. The winch plate horn mount tabs are about 5/32" too wide. Has anyone else seen this problem?
Mhonda
2022 JLR
I would suggest having RR send you a replacement winch mount, and see if that one fits. I have this bumper waiting on the shelf, ready to go on my 2022 JLR when it comes. Hoping the 21's/22's didn't have any changes to the frame horn mounting area, but I find that doubtful. I researched this bumper a fair amount before purchasing, and I did not see anyone else report the problem you are having. Let me know the outcome, so I can know what issues I may run into when I install. Good luck!
Mgriz
Mgriz
Georgia
I have been in touch with RR and they think my frame is wrong. I think that Mopar made a change because my plastic bumper is different than any video I watch installing the Arcus bumper. The big difference was the wire harness was in a molded slot, but on mine I had the harness running inside the plastic shell. Plus, if my frame was wrong why does the original bumper fit the brackets that are attached to the frame horns?
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
You have a picture showing what you're talking about? Can you not just grind it down bit to get it to fit between horns? There are a lot of people, myself included, with a 21 and aftermarket bumpers that have had zero fitment issues. Pretty sure if FCA decided to do a mid year frame change, it would be a big deal on here.
Mgriz
Mgriz
Georgia
Here are the pictures.
Jeep Wrangler JL Rugged Ridge Arcus Bumper Not Fitting Bumper1
Jeep Wrangler JL Rugged Ridge Arcus Bumper Not Fitting Bumper2
I am off basically the thickness of the steel used in the plate so grinding is not really an option. When I measure the plate from outside to outside I am 26-29/32" but between the horns is measuring 26-3/4".
Dyolfknip74
2021 JLU Rubicon
Ahh, so it's smaller, I didn't even catch that. (Canadian so Freedom units confound me ;) ) nor did I read up top, lol.
That's interesting. Again though, I'm pretty sure we would have heard about it.
Does the RR bumper fit? If so, how can RR say that Jeep changed horns if that's the case? Do they think they just changed the mounting holes? That's doesn't make any sense.
GIve a parts place a call and ask them to measure another winch plate....?
Mgriz
Mgriz
Georgia
I have not tried to install the bumper once I hit this issue. I have had multiple conversations with RR and they do not understand it. They say they have checked some they have and their plate is correct according to the dimension they have been given.
I think I am going to try your idea of the parts place next and see what I can find out.
Thanks
Dyolfknip74
2021 JLU Rubicon
Thanks
If you have stock bumper off, just measure mount points against RR bumper.
I don't trust technical answers from people who answer phones. They have a "playbook" they follow and any deviation from it is the status quo answer of of "did you reboot your device?"
Sargeoverland
Jake
Arizona
21 jlu
Mine was a little tight. Took some wiggling and got it in.
Jeep Wrangler JL Rugged Ridge Arcus Bumper Not Fitting 6B5D215E-11F7-435F-BA17-016D4225D47E
Martial Fartist
Christopher
Spring Hill, Florida
Running into this exact issue right now.
Installing the arcus and the winch plate is too wide for my 21 Rubicon.
@Mgriz, ever find a solution?
James202198
Pittsburgh, PA
2021 Jeep Wrangler JLU Willys
F&I Manager at Jeep Dealership
I have the Arcus front bumper on my '21 Willys and I had the same issue at install. It just some patience and my buddy and I were able to bang it into place with a mallet and a lot of adjusting, the key is to make sure you put the winch plate in from the bottom, its a VERY snug fit, but it will eventually slide into place just need a little force.
Mgriz
Mgriz
Georgia
I had a local shop finish the install and wire up the winch. Since I was having them do a 3.5" lift the little extra labor was all it cost me.
Mandy's Owner
Vektra
Rochester, NY
2021 Jeep Wrangler JL Sport (Mandy)
Thank you for posting this. I had the same issue. My winch plate was likely just on the high side of tolerance spec for the manufacturing fold. Same result, plate too wide to fit between the frame rails -- about the thickness of the metal. (Also brand new jeep with no damage.)
Solution: YMMV but I used my farm jack. Braced it between the rails and ratcheted it apart just a smidge. Far enough to get the plate in there. If you've got one, it can help.
Effectiveness: 4 out of 5 stars
Safety: 0 out of 5 stars
Afterward, the install went well. Except for the step where 13 hands are needed to sandwich hook plates, bumper, back plate, and frame endplates all together. I thought I was going to have a stroke. All worth it in the end. It looks awesome.
Good luck!
-V
