Rubicon LED condensation
Biohazardshrimp
South Carolina
2018 JLU
So I bought a bumper of a Rubicon and it came with the stock LED fog lights. Even when I picked up the bumper the housings have had condensation in them. I do not see any cracks in the housings or anywhere that water could come in except maybe the silver led module that screws in the top of the housing. I can pull the screws and cut the old sealant away, remove the module, clean the inside of the housing and then reseal the module. That is the only place I see that it could be letting moisture in.
Jeep Wrangler JL Rubicon LED condensation Stock Fo
Jeep Wrangler JL Rubicon LED condensation Stock Fog2
Jeep Wrangler JL Rubicon LED condensation StockFog3
Jeep Wrangler JL Rubicon LED condensation Stockfog4
Jeep Wrangler JL Rubicon LED condensation stockfog 5
lclaborn
Lance
2019 Wrangler JLU
In the same situation, following this thread.
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Replace them, or repair in a zero humidity environment. That’s the only way they’ll ever be right.
lclaborn
Lance
2019 Wrangler JLU
I came to the conclusion that water got into the fogs I have where the harness clips in. I can tilt mine and see water pooling. When I turn it over and shake it water will drip out of the back where the harness plugs in to the light. Were you able to successfully get the water out of yours or did you end up replacing?
