Rough Country Dual Steering Stabilizer
Visible15
Massachusetts
2018 Wrangler JL Sahara
Do your steering stabilizers only work on lifted builds? Currently considering the single stabilizer.
Matt2036
Charleston
2019 Wrangler JL
I am using a single stabilizer now with larger tires only a no lift. It works very well and he keeps the truck Wanting to go straight. It is a very good modification I believe for people who have larger tires.
Brooklynjlu2018
Junior
Massachusetts
2018 wrangler sahara
Reduce bump steer while improving control and handling with Rough Country’s Dual Steering Stabilizer for Jeep JL! This easy-to-install upgrade helps tame your larger aftermarket tires for a more pleasant driving experience both on and off-road.
Steering stabilizers are designed to restrain "bump steering" and front end vibration, giving added life to tires, ball joints, and other steering components and are highly recommended for vehicles running aftermarket tires. The durable 18mm chrome hardened piston rod and large-bodied cylinder dwarfs factory equipment, ensuring a more effective vibration damping each and every time you take to the trails.
Rough Country’s Dual Steering Stabilizer kit is easy to install, with a 100% bolt-on installation process that can be installed in a home garage with common tools.
Features
  • Easy bolt-on installation.
  • Improves control and handling.
  • Reduces tie rod and ball joint wear and tear.
  • Chrome hardened 9/16-inch piston rod
Notes
- IMPORTANT
  • 2.5” or bigger suspension lift required.
  • Does NOT fit stock height models.
Will this setup work with the steersmart tie rod and drag link
homebrew
paul
Washington
18 Wrangler JL Rubicon
@roughcountry will this kit work with after market diff covers?
Bskylerj
Spokane, WA
2003 Jeep Wrangler, 2011 Chevy Avalanche, 2012 Hyundai Sonata
My wife has this setup on hers. We really didn't need the dual setup, but our original one got damaged by a rock. I wasn't going to spend the money to put another one in the stock location.
The steering is firmer, it relocated the stabilizers over the tie rod where they are less likely to get damaged, and it looks cool :like:
That setup looks great. Did you paint the shocks?
Winjet
