- Ryan
- Feb 8, 2018
- Dyersburg, TN
- Website
- www.roughcountry.com
- 2018 Jeep Wrangler Sport, 1998 Jeep Cherokee
- Occupation
- Sales Supervisor
Reduce bump steer while improving control and handling with Rough Country’s Dual Steering Stabilizer for Jeep JL! This easy-to-install upgrade helps tame your larger aftermarket tires for a more pleasant driving experience both on and off-road.
Steering stabilizers are designed to restrain "bump steering" and front end vibration, giving added life to tires, ball joints, and other steering components and are highly recommended for vehicles running aftermarket tires. The durable 18mm chrome hardened piston rod and large-bodied cylinder dwarfs factory equipment, ensuring a more effective vibration damping each and every time you take to the trails.
Rough Country’s Dual Steering Stabilizer kit is easy to install, with a 100% bolt-on installation process that can be installed in a home garage with common tools.
Features
- IMPORTANT
Features
- Easy bolt-on installation.
- Improves control and handling.
- Reduces tie rod and ball joint wear and tear.
- Chrome hardened 9/16-inch piston rod
- IMPORTANT
- 2.5” or bigger suspension lift required.
- Does NOT fit stock height models.
