Rock Slide Engineering Gen 3 Slider issues
Neutrino
Canada
22 JLURD
Does anyone know what could be going on with my Rse steps. I just installed them on my 392 a week ago and having some issues with them. My passenger side occasionally gets stuck in the down position. I fixed it by unplugging and plugging the rear sensor back in. it will work for a few days and then get stuck again. On the drivers side, my step will work when sitting in the driveway and then as soon as I drive somewhere and get out the step is stuck in the down position until I unplug the rear sensor. I have adjusted the magnets a little bit but it seems like I’m having sensor issues. Rse is sending me some new sensors but I’m no convinced this will solve it
It is most likely a door sensor. Best way to eliminate the door sensor is to check for continuity on pin #4 to pin #2 and pin #5 to pin #2 when the issue occurs. ONLY do this with the fuse pulled OUT! If you don't have continuity then the issues is not the door sensors. If you do, then the respective door sensor is the issue. Pin #4 is passenger front and pin #5 is passenger rear.
rforbes
Raymond
Seattle, WA
2024 Wrangler Rubicon X 4xe
The motor has a plastic gear inside it as long as its just stripped gear teeth. Once your warranty expires like mine did... you can disassemble the motor and rotate the gear 33 degrees. You can do this twice per motor before buying a new after market motor for $30ish bucks.
ooh, that is good to know. Thanks for the info!
