cball508
I just installed my Gen 3 RSE sliders this weekend. I've come across two problems and didn't know if anyone has had similar issues. First, I'm getting a loud banging when the passenger side closes. Almost like it's banging metal on metal. I installed the slider and didn't have the issue. It seems like the first time I stepped on it, it started making that noise after that. I've called RSE. They had me adjust the nut on the tensioner spring, but that didn't help. RSE said they would send me rubber bump stops to help with the noise. The right side is buttery smooth, no issues.
Also having a small problem with the left side circuit board connection. The plug is fully seated, tab locked, but the slider will sometimes not open. I have to disconnect the plug, reconnect it, the system resets, and it works again. I've been told to pull the fuse to "reset the system" the next time, but curious if anyone else is having similar problems?
Passenger side (no issues):
Driver side:
Driver side:
