Rock Krawler Upper Spring Isolator Modification (4xe/392/Diesel)
KebertXela
Sean
King George, VA
2021 Hydro Blue Rubicon 4xe
I recently installed a 3.5" Rock Krawler X-Factor "No-Limits" suspension system on my 2021 Rubicon 4xe. Everything went pretty smoothly following the instructions for the JL X Factor Series Mid Arm found on Rock Krawler's website. However I ran into one very noticeable issue with the Front Springs bowing badly inward towards the frame. Searching the forums for a solution, I've seen other people with this issue - particularly those with 4xe, 392, and Diesel Wranglers - but could not find any detailed solution.
Contacting @Rock Krawler Suspension, they quickly provided a video explaining a fix by modifying the upper spring isolators.
Link to video
Not really sure why this information isn't provided in the instructions, which haven't been updated since June 2021.
[One other big significant note for 4xe owners: You are not able to reroute the parking brake cables under the cross member. Jeep redesigned the paneling (at least on the 4xe) which makes it impossible to access the parking brake cables from the front side of the cross member. You will need to get a parking brake cable extension kit like the one Teraflex offers or longer cables.]
I figured I'd document this in case anyone else is in my position in the future.
Before Pics:
Jeep Wrangler JL Rock Krawler Upper Spring Isolator Modification (4xe/392/Diesel) IMG_2775
Jeep Wrangler JL Rock Krawler Upper Spring Isolator Modification (4xe/392/Diesel) IMG_2774
First, after lifting the jeep and removing the tires, make sure to disconnect the following:
  • Drag Link (at the steering knuckle)
  • Track Bar (at the Frame mount) (found this easier as the axle joint was a pain to get in the first time)
  • Remove both sway bar links
  • Remove Shocks from bottom mounts
  • Electric Locker connector
  • Axle Disconnect connector
  • Diff breather tube
Note: If you don't have access to a lift and are using a floor jack and jack stands, you will need to rise the jeep frame pretty high in order to drop the front axle enough to get these springs (3.5") out.
Next, using a paint marker, I marked the isolator, spring, and bump stop so I have a reference for when I rotate the isolator and put everything back.
Jeep Wrangler JL Rock Krawler Upper Spring Isolator Modification (4xe/392/Diesel) IMG_2778
Now, unbolt the bump stops and remove the springs and isolators.
To modify the isolators, I used a grinder with a 80 grit flap disc and ground down the edges until they were pretty flush with the existing spring grove. Do this to both isolators.
Jeep Wrangler JL Rock Krawler Upper Spring Isolator Modification (4xe/392/Diesel) IMG_2785
Finally, make a mark on the opposite side of the isolator (180Âş) from your first mark to allow you to line it up with the mark on the spring and bump stop.
Reinstall the springs and isolators.
Jeep Wrangler JL Rock Krawler Upper Spring Isolator Modification (4xe/392/Diesel) IMG_2784
Reinstall everything else as you compress the springs:
  • Bump stops
  • Shocks at bottom mount
  • Both sway bar links
  • Wheels
Once the Jeep is sitting on its own weight, torque all reinstalled mounting bolts to spec.
After Pics:
Jeep Wrangler JL Rock Krawler Upper Spring Isolator Modification (4xe/392/Diesel) IMG_2796
Jeep Wrangler JL Rock Krawler Upper Spring Isolator Modification (4xe/392/Diesel) IMG_2795
Springs are now sitting straight!
This modification should be a temporary fix, Rock Krawler is supposedly working on a new upper isolator (probably similar to the one MetalCloak offers) that will correct the bow and you won't need to do this modification anymore.
A.leec34
Wv
23 jlu rubicon
Has there been a release of a correction part I installed the mopar diesel 2in lift on my 23 jlur 3.6 and both front springs bow inward and contact the frame when flexed I’m willing to modify the upper pad but would prefer to buy a correction pad instead ?
Roky
Roky
https://rockkrawler.com/front-neutral-spring-isolator-jl-jt/
If you’re using Mopar lift springs then you need to use oem upper isolator since they are modeled after the oem springs… you can get the RK lower spring perches to help with the bowing…… if it’s hitting the frame when stuffed then that’s normal…the spring will bow inward when fully compressed, you can add more bump stop to help it not bow as much……
A.leec34
Wv
23 jlu rubicon
I went ahead and ordered the neutral top isolator I think that will help a lot cause mine is made thicker on the outside which would further the Bowing so hopefully this helps
Roky
Roky
The neutral isolator is for springs that the tail (end) of the spring is flush with the last coil…( RK, MC, etc…) The Mopar lift springs the tail of the spring sits a little higher that’s why the oem isolators are tapered…… if your spring is bowed at ride height then you need the RK lower perches to help with that….. if the springs are straight at ride height and only bow inward when compressed then that’s normal…….does it look like this…..?
Jeep Wrangler JL Rock Krawler Upper Spring Isolator Modification (4xe/392/Diesel) 98B63232-1551-44E2-9C0D-697EC83464B2
A.leec34
Wv
23 jlu rubicon
Here’s pics of mine sitting flat and pics flexed
Jeep Wrangler JL Rock Krawler Upper Spring Isolator Modification (4xe/392/Diesel) IMG_6085
Jeep Wrangler JL Rock Krawler Upper Spring Isolator Modification (4xe/392/Diesel) IMG_6086
Jeep Wrangler JL Rock Krawler Upper Spring Isolator Modification (4xe/392/Diesel) IMG_6087
Jeep Wrangler JL Rock Krawler Upper Spring Isolator Modification (4xe/392/Diesel) IMG_6092
