Capt. Don
- Don
- Aug 16, 2022
- Puerto Rico
- 2022 Jeep Wrangler Unlimited High Tide
- Occupation
- US Merchant Marine Master, 100T
- Vehicle Showcase
- 1
You are making me a believer in Mud-Terrains. I see much more mud than sand in the mountains here. Good point. As far as vehicle speed, here is the catch. There was a 12” near vertical rock at the crest waiting for my left front wheel. I did not think that I could bang over it with speed.As others have said, aired down MTs are going to way outperform those KO2s in that type of situation. But also, and this is controversial and tricky, speed. If, even with proper tires, you can't get up slowly, you need to add speed - and not wheel speed - but vehicle speed. As always, a judgement call on if it's wise in a particular situation, but sometimes a little momentum goes a long way. Obviously this increases the risk of breaking things if overdone, but backing up and adding a little speed, and a little more, and a little more until you clear the obstacle can help on muddy climbs. I tend to be really conservative with vehicle speed and go slower, but there is definitely something to be said for momentum - within reason.
However, before that, I 100% recommend MTs instead of KO2s. PR's got to be way too wet for KO2s to be reliably hooking up and you're going to struggle more than you'll enjoy, more than likely IMO. Any decent MT will outperform KO2s in that environment.
