Removing Scuff on Fender ?
CPO Rob
Rob
New Jersey
2021 Rubicon Unlimited, Black w/red
YIKES! I scuffed the rear driver's side fender. Not bad, but a scuff nevertheless. How do I get that out? Tried compound, that didn't work.
jludave
The Isle of Long
IT Manager
jludave
The Isle of Long
IT Manager
Not going to be easy to do, unfortunately. You can try using something like this to see if it will at least restore the black finish. A bit of light sanding might work, after which you'd also use the trim restore. You can also try using a heat gun/hair dryer to gently heat the area and try to smooth out the plastic.
LongTimeListener
Arizona
JKURHR
You’ll have to learn to live with it. You can mask it to some extent with a back-to-black type product.
I wouldn’t go sanding anything.
Pinion
Rob
Hull, MA
1971 FJ40, 22 Rubicon Unlimited
Project Manager
Just leave it.
CPO Rob
CPO Rob
Rob
New Jersey
I think you are right
