Remote Windows
CJ SCION
Tim
Michigan
2024 JLU Willys
Tired Again
Had the Global Windows feature on a Ford F150 and loved it for those sudden downpours while parked outdoors. Will Jeep ever get on board with the Global-Open/Close Window Feature?
JEEPIDON
Charlie
Forsyth, Missouri
2021 Rubicon, 2021 Gladiator Rubicon, 2013 Ram2500
Retired - Business Consultant
No offense, but how would anyone answer this question?
I think you are on a quest with no destination. They'll be plenty of speculation but no real answer.
MonLee
Stan
NJ
2021 2 Door Sport S
Approx 2023.
mbartelt
Carson City Nevada
2018 JLUS
A clever electrical engineer could probably make a module that could do this... but it wouldn't be oem.
CJ SCION
CJ SCION
Tim
Michigan
2024 JLU Willys
Tired Again
CJ SCION
CJ SCION
Tim
Michigan
2024 JLU Willys
Tired Again
I am rather satisfied in the progression of this thread. Thank you for your contribution.
MacombRoger
Roger
SE Michigan
2018 JLUR Ocean Blue
Solution Architect
^^^ What he said.^^^
I have it. Works great.
^^^^ What he said ^^^^^
Have had it since it first came out, works great. Only thing i recently noticed, is you can't one click raise the front windows, then click the back windows, as the front stop going up, and vice versa. Not sure I remember that issue in the beginning.
Terminex
Omaha
2021 JLUR 4XE
Fixing stupid....
yup, That is how mine has worked since day 1. if you watch when it raises and lowers, it always does 1 pair, and then the other pair. I am guessing it is a power limitation, as it is a lot of amps to raise & lower the windows. (found out the hard way when i was lazy on the first jeep and tried to tap the 12v plug in the dash for the battery power instead of actually running a wire. popped that fuse the first time I tried to do the windows.)
MacombRoger
Roger
SE Michigan
Solution Architect
haha I popped that fuse 4 times before I got smart and actually ran a wire to the fuse block under the hood. :)
