recommended odb2 reader with app for 4xe?
Andric
New Mexico
2023 Sahara High Altitude 4xe
Just wondering if there is one that would be recommended over others for 4xe diagnostics. Currently looking at the bluedriver dongle here but was wondering if there is preferred one for the 4xe.
Thanks in advance
Ormond Beach, Florida
Retired at 55 ..
@Andric
Base what OBBDll Scan Tool you go with based on what app(s) you plan to use with the scan tool ...
You would want to buy a scan tool that is known to work well with your vehicle and again, that works well and is recommended by app support people.
Remember, you will also need to buy a security gateway bypass module along with the scan tool.
I suggest you buy an ECRI security gateway bypass module.
https://ecri.app/products/ecri-secu...OgRhPDv9fRE2FfWLyBfbmjcqYb0uIWDikTq11iP0NLJZY
Also, most guys/gals will tell you to also buy a ZAutomotive security gateway extension cable.
https://www.zautomotive.com/product/z_sgw_ext/
Bri_NYC_Rubi4xe
NYC
2021 Wrangler Rubicon 4xe
watching thread as i'm curious to see what people are using on their rigs as well...
Bill_BCNtoNY
NY
Ocean Blue JLU Sahara 3.6
Advisor to Boutique Consulting Firms and Solo Practitioners
I only used my Fixd what I already had - it’s very basic but also cheap. Picked it up for $30 on a Black Friday say a few years back.
ag4ever
‘82 CJ-8, ‘82 CJ-8, ‘83 CJ-8, ‘26 Moab 392
Cheap Bluetooth vLinker MC+ and JScan app. Works great. The gateway bypass is only needed to clear codes and write setting changes. I can read just fine without one installed.
Retired at 55 ..
Kinda pointless though to have the OBDll scan tool, have paid for JSCAN and.... and all you can do is read the code(s).
1st time your JL goes into limp mode, etc., you will wish you had a dedicated SGW bypass module or an old school Chrysler 12+8 Programming Cable, in play so you can clear the code that was thrown because of the issue.
I was wondering why the OP, thought there was something special lets say with a 4xe, JL that would necessitate a certain OBDll scan tool other then a scan tool "Highly Rated" by JSCAN or another app. he were opting to use..
ag4ever
Agreed, I have the cable in a box under my seat. But, it is not installed and won’t be until I need it. Plus, it is less than $20, so why not get it just to have it. But I don’t like the idea of bypassing the security gateway. It is there for a reason, a long shot reason, but still…
HK1s
Canada, Montréal, QC
23 2dr sport 3.6etorq AT
after tax in Canadian dollars, USD -25%
chrysler 12+8 cable $20
V-gate icar pro bluetooth 3.0 $28 (this only work with android)
jscan license $30
this is good for checking all the data and making adjustment
I have got hood alarm working, tone down the auto headlight sensitivity, configured LEDs and light dropout behavior.
Retired at 55 ..
jscan license $30
Better way to go is with a dedicated security gateway bypass module. Yes, will cost you $10 more then old school, Chrysler 12+8 cable but for multiple reasons a better way to go.
HK1s
Thing is I did not even know the product existing lol. I'm not changing the vehicle settings everyday, After im happy with it, I will plug the sgw back and use the regular obd port.
Tbh my cable management is pretty good, there is that metal bar below the steering wheel right, I looped the 12 8 cable over it and put on the trim piece and the cable is locked in place and not dangling , i can plug in things into the bypass with one hand too.
Retired at 55 ..
My post was aimed at guys/gals that will be buying hardware for use with JSCAN.
Just trying to encourage them to buy hardware that does the job ... does it best lets say and also hardware that is easily resold in the future..
In regard to the dedicated security gateway bypass module... You hook that to a security gateway extension cable and then you have easy access to the ends so you can plug in your hardware.
Trivia: The Polish guy, Piotr Bialic that brings us JSCAN, told me he uses a dedicated security gateway module and not a Chrylser 12+8 Cable.
mrtm1970
Marshall
Orlando, FL
2019 JL Unlimited Rubicon
Mechanical Engineer
OK…I just got these for the JScan…do I need anything else?
Jeep Wrangler JL recommended odb2 reader with app for 4xe? 49D47655-EB00-4869-87D1-A8329143C21A
Retired at 55 ..
Why the bbflyobd extension cable... The OBDll port is right there.... as in easy access... and the scan tool is Bluetooth enabled.
Return that bbflyobd extension cable and buy a ZAutomotive security gateway extension cable...
Remember you also need a SGW bypass... Do go with a dedicated security gateway bypass module and not Chrysler 12+8 cable..
mrtm1970
Marshall
Orlando, FL
Mechanical Engineer
It actually came with the OBDLink MX+ and was actually surprised when I opened the package…got it from EBay.
Retired at 55 ..
Just bought…so what gets connected to what to use the JScan?
The two cables you disconnect from the security gateway plug into the ECRI dedicated bypass module. The OBDLink scan tool plugs into the OBDll port.
I strongly .... very strongly encourage you to buy the security gateway extension cable from ZAutomotive and wait for it to arrive before you fool with the SGW connections.. This way, you will only have to deal with the SGW cables once...
Here is a pic of the connectors (circled in red) way up there that you will deal with..
