Recommend an impact power tool thingy
Jeep Junkie
Muhammad
Seattle, WA
2024 JL Wrangler Willys
Guys, in YouTube videos, mechanics have this gun and they remove screws and stuff so fast and nice. I want something like that. Something that will work with my air filter housing, and other stuff like my skid plates and stuff. Please recommend a nice thingy. I want to work like a pro now 😎
WillysMeow
Corruptifornia
Bought my first new Jerp! :)
Bit wrassler
My DeWalt 20v tools have been great for years, mostly made in USA too. Milwaukee is or was all USA made, but more money. That said once you have a brand stick with it as it's very expensive to switch over.
I have this one and it's been great so far, it's very compact length good for tight spots and not super heavy.
DEWALT ATOMIC 20V MAX Cordless Brushless 1/2 in. Variable Speed Impact Wrench (Tool Only)
https://www.homedepot.com/p/DEWALT-...eed-Impact-Wrench-Tool-Only-DCF921B/316627128
The ATOMIC 20V MAX* 1/2 in. Cordless Impact Wrench was designed easily to handle various fastening projects. Get up to 300 ft-lbs of fastening torque and 450 ft-lbs of breakaway torque with this compact power tool that offers easy maneuverability without sacrificing power. Choose between 4 speed settings while the Precision Wrench (TM) control feature and Timber Screw mode allow for reliable high-level performance, operability, and versatility.Dark work areas are no problem with this Cordless Impact Wrench, which comes with an LED work light for visibility in dimly lit spaces. Battery not included.
Highlights
ADAPTABLE FASTENING RANGE: Up to 300 ft-lbs of fastening torque and 450 ft-lbs of breakaway torque
ENHANCED USER CONTROL in a variety of applications with 4 speed settings
Prevents Over Tightening and fastener run-off with Precision Wrench(TM) control
BRIGHTEN DARK WORKSPACES with onboard LED and brightness control
QUICKLY CHANGE BITS: Hog ring anvil for rapid, secure socket changes
OPTIMIZED SPEED IN WOOD with timber screw mode
BUILT FOR LONG LIFE: GFN Housing provides resistance from damage caused by some oils and solvents
Product Information
Internet # 316627128
Model # DCF921B
Store SKU # 1006299577
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
Highlights
Product Information
Model # DCF921B
entropy
Foothills of the San Gabriels
OF top 1% content creator
Harbor freight hercules. Perfect for the hobbyist and cheap af. No need to go all fancy unless youre using them constantly. And make sure you also buy an electric wrench for tight spots. A good break bar for spots where your impact gun cant fit in followed with tbe electric wrench to quickly remove the bolt.
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
I will show up at Harbor Freight this evening and see what they got 🤩👍
WillysMeow
Corruptifornia
Bit wrassler
Got one of these for RC cars with lots of screws and it's useful on small screws and bolts with my Jeep too...normally I avoid all HF power tools lol.
BAUER 4V Cordless, 1/4 in. Screwdriver with Integrated Flashlight Kit with 4 Insert Bits and Wall Charger
https://www.harborfreight.com/4v-co...rger-64313.html?hftm_sc=577&utm_source=google
I learned long time ago, buy quality once and save time and money, plus support made in USA when possible, but to each their own. All the little electric screwdrivers that I researched are made in China, sometimes not much you can do about that. :/
Heimkehr
Pennsylvania
2021 JLU 2.0T
Guys, in YouTube videos, mechanics have this gun and they remove screws and stuff so fast and nice. I want something like that. Something that will work with my air filter housing, and other stuff like my skid plates and stuff. Please recommend a nice impact power tool thingy. I want to work like a pro now
Don't use an impact wrench on the small screws that secure the Jeep's plastic air filter housing. That's not what that tool's power is intended for. It should serve the informed user very well for tasks like wheel lug nut removal and similar tasks.
Consider also using an impact wrench just for loosening (i.e., counterclockwise) rotation. When used for tightening hardware, an impact in the wrong hands -- and with respect, that'd be you at this very moment -- can too easily strip threads and/or damage whatever is being worked on.
Here's an excellent starting point, one wholly suitable for those airbox screws. After getting comfortable with it, you can then consider moving on to more powerful power tools.
Blues Fan 30
St. Louis
Ive got the bauer battery powered impact from harbor freight and it worked amazing for my axle swap and lift. For smaller items I use this (including removing and reinstalling the door and hard top bolts. I break them loose with the ratchet and also give a final tighten with the ratchet but this saves a TON of time). https://www.amazon.com/gp/aw/d/B0D62HH4VV?psc=1&ref=ppx_pop_mob_b_asin_title
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
Rodger! Actually the thing is that changing the transfer case fluid is so freaking simple that I'm getting tempted to change it and my stupid skid plate is in the way, so I will use the impact gun on that first for some practise. I'm a super rookie, so please try to understand, I need some practice.
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
Can't wait to stop at Harbor Freight this evening to check their thingies 🤩👍
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
I already gave a notice to my Jeep mechanic 😃👍
Jeep Wrangler JL Recommend an impact power tool thingy Screenshot_20250924_165128_Messages
