rear plastic window [roll up]
tony58
tony
rome pa
2024 2 door rubicon,77 fj40,2010gt500,2021f250
have a 24 rubicon with the bestop trektop slant back top has anyone came up with an idea on when the rear window is rolled up and, on the jeep, how to secure in the up position called bestop but no luck
OffRoadMedic392
Dimitri
Clearwater, FL
2022 Wrangler 392
Emergency Medicine
Great idea, it would be so much more convenient if i didn't have to remove the rear window every time and save myself 30 seconds lol. I'll take a look this weekend and see if I can rig something up with velcro
drachenfels
Carter
Dayton
R1250GSA, MOAB 392, F150
If you're going to roll up that window regardless - roll a towel in it (put it on the exterior, and roll it up so the towel keeps it from rubbing dirt against the plastic); it'll cut down on the scratches that make it hard to see out of. Old YJ trick... DAMHIK.
tadeh17
tadeh
Belgique
fiat
Unfortunately, there isn't really a built-in system to securely hold the roof when the rear window is up. Many owners simply use Velcro straps, elastic clips, or magnetic fasteners to keep the canvas in place temporarily.
BXFXJeep
Toronto, ON
2021 4xe Sahara
The JK, and TJ had loops, i can't remember as far back as the YJ.
You can probably loop two straps on the rear bar to secure it, not sure if that is possible, I don't know anything about that soft top.
UncleArt
Arty
Western Washington
2022 Wrangler JLR 3.6l, 6MT, 4.88s
UncleArt
Arty
Western Washington
tony58
tony
rome pa
sorry just found the 2 door one have you driven your jeep with the window up if so any problem's with it
UncleArt
Arty
Western Washington
Thanks, they say it fits a 4 door but I see you have a 2 door am I correct
True, but I don’t think it matters how many doors. You just need to select the proper mechanism for the particular top you have. In your case - the slant top…
edit: didn’t realize you were a 2-door also!
UncleArt
Arty
Western Washington
No problems at all. Nice air flow with no buffeting. The arms lock open with little pins - very secure…
tony58
tony
rome pa
Thank you very much 15% off sale this weekend will order one
tony58
tony
rome pa
UncleArt
Arty
Western Washington
where did you get the water can dispenser??? on your tailgate looks like something I could use
It’s a Dometic Go faucet. I got it & 2 jugs from Amazon. The tailgate is aluminum so I double stick taped a round steel plate down for the magnetic faucet to attach to.
Round Plate
