ronhallam
- Ron
- Sep 28, 2021
- Wellington, Colorado
- 2018 Rubicon Unlimited
Ok, Lockers light came on while in 2 wheel drive. I take my 2018 Rubicon JL with 47,000 miles to the Jeep dealer to check it out because I still have 6 months left on the 5 year power train warranty.
They ordered new sensors and other parts under warranty. The jeep tech was having problem putting it back together and then realized it had been regeared to 513, and I knew that.
Luckily, they stood by the parts for warranty and didn't charge. But he still couldn't get the lockers to unlock. He said if I put the original gears back in the lockers would work. I do have the parts. I talked to a lot of knowledgeable people since then and said that doesn't make any difference.
SO, I called the previous owner and ask who regeared it and he told me. I called and they said, BS it should work. The jeep shop said drive it home. I did and parked until the other shop could look at it. As I was driving it to other shop the left rear brake area was blowing out smoke, pulled over and fluid leaking out the axle just above the rotors. I had it towed back to Jeep and he said now the axle was trashed. What kind of tech would say drive it home? they should of told me to be safe tow it the other place.
Now the Service Manager says since you changed out the gears you have to change the lockers to match? IS THAT A TRUE STATEMENT? I contacted the shop that did the switch and they advised they never swap out lockers.
Everyone else I have contacted says NO, you don't have to change the lockers!!!
I feel the Jeep dealer at least owes me an axle, and I will take it somewhere else to fix!!
Any input would be appreciated!
