Rear/Front axles/Fluid
longfiredragon
Darryl
Cocoa Fl.
2021 JLUW Sport 2.0 L Turbo
Hey all
Sorry if this has been answered, couldn't find it.
Wanting to change differential fluid in both the front and rear axles.
How do I know which I have? It's a Willys with I thought has the Dana 30 up front and the Dana 44 in the rear with limited slip.
But there are multiple listings with different fluid called out.
Thanks
Jeep Wrangler JL Rear/Front axles/Fluid Screenshot_20231001-091242
Ormond Beach, Florida
Retired at 55 ..
You can get a copy of the Moroney (window sticker) and a build sheet in regard to your JL. You will need the VIN# of your JL.
https://www.jlwranglerforums.com/forum/threads/➡-?-jl-build-sheet-window-sticker-ez-lookup-?.108282/
As for diff fluids you'd use and lots of pertinent info in regard to the diff fluid change, read through this whole thread.... Read through the whole thread as fluid recommendations changed as time went on... and with more info from Dana.
Read through this whole thread..... Be sure to read all posts in the thread.
https://www.jlwranglerforums.com/forum/threads/differential-oil-change.47318/
longfiredragon
longfiredragon
Darryl
Cocoa Fl.
Thank you sir.
longfiredragon
longfiredragon
Darryl
Cocoa Fl.
So, I have my window sticker. But the link posted doesn't work. It states signal lost, check back later?
Retired at 55 ..
Site must be temporarily down.
Read at diff thread. You use same fluid regardless of which Dana you have. Buy fluid that has additive. If your JL requires additive your good to go. If your JL does not require additive, no harm if the fluid you use has additive.
hoch
Hoch
UT
2018 JLUR 6-sp
Fail safe: Pick up fluid at your dealer. ?
longfiredragon
longfiredragon
Darryl
Cocoa Fl.
Thanks for the replies. I think I have it sorted.
This may not be the right place for this question, but I also want to torque check everything on the chassis. The specs. Should be in the manual.
But being a jeep newb I don't know what parts are what under there. I remember seeing on here someone posted a pick of the suspension parts labeled so you knew what everything was.
Anybody know where that pic. Is on here. If not I guess I will do some Google searches.
Thanks again.
Terrymo
Terry
2023 JLURXR 3.6 ET
Thanks again.
Jeep Wrangler JL Rear/Front axles/Fluid IMG_2024
Jeep Wrangler JL Rear/Front axles/Fluid IMG_1827
longfiredragon
longfiredragon
Darryl
Cocoa Fl.
You guys are awesome. Thank you so much. It's my first time getting under there and torque checking everything.
I will save the info. For next time also.
Thanks again
